Hiby R6 Pro II (2023 Edition) - Launch, Hype, Thoughts & More
May 6, 2024 at 11:17 AM Post #1,936 of 1,981
Typically these cards actually physically cannot go in the wrong way, so no danger.
That’s not true. If forced the micro sd card can also go in the wrong way and then it’s a pain to remove it, might even cause some damage.
@Colif You know you have inserted it properly if the last 20% has a spring motion that clicks into place when fully pushed in. If there’s no spring action and it feels rough to push in then you are inserting it wrong.
May 6, 2024 at 12:17 PM Post #1,937 of 1,981
Very true, hold my hands up as I am a guilty one. Done this on my Ibasso when I first got it, card went in wrongly, did not work ( probably shorted the card) so my wisdom told me try it on the the Nikon camera, smoke came out and camera was fried. So am very very careful now with sd cards. Expensive lesson.
May 6, 2024 at 1:35 PM Post #1,938 of 1,981
HiBy customer service acknowledged there is an issue with the Max Battery setting and they will try to fix it. No ETA.
May 6, 2024 at 6:22 PM Post #1,939 of 1,981
OK, sorry if I gave bad advice about SD card insertion. But, can I ask those who’ve managed to put the card in wrong, did you have to apply excess force? I never applied excess force and the proper direction was obvious to me when small force failed to insert the card because it was oriented incorrectly…
May 7, 2024 at 3:03 AM Post #1,940 of 1,981
Cannot remember exactly as it was a few years back however from what I recall the card slot allowed the card to go in incorrectly, there was a lot of play so card could go in even when not put in straight so it went in wrongly, am sure I had read at the time this happened to at least another individual.
May 7, 2024 at 3:28 AM Post #1,941 of 1,981
Waiting for microsd card and reader to show up in mail. I realised I needed to format it before I put it in anyway... inserting in reader might clue me in anyway.
Looking on YouTube I found video of a R6 where it had a sim tray - this doesn't appear to - and the sdcard was put in so that the label faced the back of the unit.
But looking inside the slot, the metal part appears to be on side facing rear of DAP which would imply to me the label should face display.
So just as confused as before :)
I got a 512gb sdcard so don't necessarily want to guess which way is right way
May 7, 2024 at 9:18 AM Post #1,942 of 1,981
Pins facing up.
May 8, 2024 at 12:31 PM Post #1,944 of 1,981
Even more cool is that you can run autoEQ on any unit listed on squig.link and export the results to a file that can be read directly by the PEQ :)
Which Autoeq.app equalizer app export type works the best with the new PEQ? I tried a few but I am getting data error. The file formats for some are similar to squig.link except for shelf filters. When I set up a 10 band custom PEQ without shelf filters, it still wouldn't import, so it's unclear what's happening.
May 8, 2024 at 8:32 PM Post #1,945 of 1,981
Hi, I just tested this, there's actually not much to it, it's the custom parametric EQ, you can have shelf filters and up to 10 bands of anything even. You just have to edit the file so that the frequency numbers are whole numbers not decimals. I'll see about updating support for this in the next version.
May 8, 2024 at 8:49 PM Post #1,946 of 1,981
Got it. Whole numbers only. I was wondering what was going on as the files looked to be the same format.
May 15, 2024 at 1:15 PM Post #1,947 of 1,981
Anything that shows what all the plug ins do?
I got a set of Letshouer S12 Pro earlier and it sounded really tinny. It was only after about 9 hours I noticed I had enabled a plug in at some time and removing it made everything sound better again. Now need to re evaluate how they sound.
May 15, 2024 at 1:19 PM Post #1,948 of 1,981
Ah...ain't that just the worst? :beerchug:
-Ed
May 15, 2024 at 11:49 PM Post #1,949 of 1,981
What plugin was it and how was it set?
You can try tapping the (i) button next to each plugin.
There's a page dedicated to the DRX10K: https://www.head-fi.org/threads/introducing-the-all-new-hiby-drx10k.968627/
May 16, 2024 at 5:56 AM Post #1,950 of 1,981
I had only enabled it so it was at default settings. It was the DRX10K one.
I didn't see the menu that lets you adjust values at all, as I hadn't tapped the name (didn't realise it was a link).
Makes me wonder what else I have set accidentally... goes looking.
