SONYES
- Nov 28, 2013
I adaped the EQ for the foobar graphic equalizer; sounds great!
You can download it here:
https://www.dropbox.com/sh/hif3e1rt58tjwy6/AAAWVspOL4wuj76pkbO2uU6za?dl=0
I noticed that with the BW Sheepskin pads the seal is so tight it creates a suction and slight pushes on the housings will mess with the sound. Minor annoyance.
I did little experiment and taped up velour section of the focuspads, and behold: Let there be sub bass!!!
So if i find full leather pads somewhere, how do i connect them in the Hifimans?
Yeah, i really dont want to ruin stock pads on the process.https://www.amazon.com/Brainwavz-Angled-Memory-Foam-Earpad/dp/B00ZY8PGJI
There is a ring inside the pads you have now that come out and will insert inside these. Fair warning, you will ruin your stock pads by putting new ones in, but I've been running these since I got mine and they are much better imo.
They work fine.. It takes a bit of stretching but the fake leather is forgiving
