Dixter
- Dec 21, 2011
for my
@6Channel ... for my op amp rolling I use either the Burson or the Sparkos.. Those change the sound sig significantly... so you would need to do some research to see what they would do for your setup... warmer selection or brighter airier type sound sig... and of course once you get them installed you would need to spend enough time for your brain burn in to make sure of what you changed you like it or not... the down side is they aren't cheap but they do sound very good... for what they offer as to sound sig you should be able to look around the forums to see what they might do for you... check on the Burson Amp posts and you should be able to get info on both Burson opamps and or the Sparkos... and Burson just released a new version but I haven't heard them... does this help you ??Wild question for y'all: I just plugged an LM4562 into the little powerhouse amp feeding my V2, and VOILA ! It sounds terrific, primarily because I don't need to EQ the 2K trough !! Unfortunately, I'm now missing key HF elements I enjoy from my standby NJM5532DD. I wonder if any on this board have relevant experience with any of the 4562, 49720, or 49860 variants out there. This is a great-sounding chip, but the hi-hats, string overtones, and live atmosphere are greatly suppressed [no "air"]. I would REALLY love to ditch my EQ apks. I've read too many reviews about the sound signature variation in this chip family, so thought I'd start here to see if anyone has a recommendation !
