Yep, fortunately Aune has a 150 ohm spec for the amp and that's what I used to calculate voltage and I came around the same number as you.The S17 can do 16V output and MJ3 can do 17V. But that's a difference of 0.5dB so any differences there are likely just going to be down to which of the two amps you prefer the sound of.
Remember, for tungsten, the 32 Ohm power spec is completely irrelevant. That gives an indication of current capability but the limitation with Tungsten is voltage. You need to look at the 300 Ohm spec. (0.9W on S17 and 1.0W on MJ3)
So I'm missing 4v in order to reach the recommended and "magical" 20v number to run Tungsten SS, in theory with my amp I could drive tungsten SS up to 109dB(not planning to listen that high tho lol!), do you think that would be enough in order to get he most out of tungsten or I'm gonna be missing a lot?
