Holo Audio Cyan 2 DAC
Dec 9, 2023 at 10:06 AM Thread Starter Post #1 of 806
JerseyD
ex-NJ-NYC, now HTX
Holo Audio has introduced its new Cyan 2 DAC:
“Introducing Cyan2, the pinnacle of audio precision and clarity. Immerse yourself in a world of unparalleled sound quality with this high-end digital-to-analog converter (DAC). A little giant. Utilizing cutting-edge R2R discrete ladder DAC technology, Cyan2 delivers an authentic and true-to-source audio experience. Say goodbye to oversampling artifacts and embrace the purest form of sound reproduction.
Designed for audiophiles and music enthusiasts, Cyan2 supports non-oversampling, providing a pristine audio signal that stays true to the original recording. Elevate your listening experience to new heights with DSD 1024x support, ensuring every nuance and detail of your favorite tracks is faithfully preserved.
Upgrade your audio setup with Cyan2 and rediscover the art of sound. Immaculate craftsmanship meets state-of-the-art technology, making Cyan2 the go-to choice for those who demand audio excellence.”
Description​
Product Description:
The newest HoloAudio offering is the Cyan 2 DAC. We are quite proud of the Cyan 2 and confident in saying we think you will find it most impressive as well. It’s a true balanced discrete resistor ladder DAC with both PCM and DSD support packed into a smaller footprint of desktop space. The Cyan 2 has several “trickle down” technologies from it’s bigger brothers and we are excited to introduce this product at a more affordable price.
Overview
Cyan 2 “青2”, A new generation DAC of fully discrete resistor network (commonly known as R2R). Relative to its predecessor the Cyan “青”, the Cyan 2 “青2” has the following improvements:
• Equipped with R2R network and vector step resistor network at the same time. The R2R network is used for primary digital-to-analog conversion of the PCM stream, and the vector step resistor network is used for primary digital-to-analog conversion of the DSD stream.
• The new generation of de-glitch technology can provide full-amplitude de-glitch without increasing the noise floor and other adverse effects.
• Based on this new generation of technology, Cyan 2 “青2” Can provide >106db SINAD and >127db dynamic range.
• USB supports sampling rates up to DSD1024 and PCM 1.536M.
• The USB interface uses proprietary firmware with ultra-low latency, a highly reliable data transmission, ideal USB eye pattern measurements that contributes to 2-4 times higher performance than official firmware.
Digital input
COAXIAL, OPTICAL, AESPCM 44.1-192K (24bit)
DSD 64X (DOP)
USB (galvanically isolated)PCM 44.1-1.536M (32bit)
DSD 64-512X (DOP)
DSD 64-1024X (Native)
I2SPCM 44.1-1.536M (32bit)
DSD 64-1024X
Analog Output
PCM 48K NOSTHD+N 0.0005% @1K (-106dB)
DNR -127dB
Voltage Output 2.5Vrms(RCA), 5.0Vrms(XLR)
DSD 128XTHD+N 0.0002% @1K (-114dB)
DNR -115dB
Voltage Output 1.25Vrms(RCA), 2.50Vrms(XLR)
Physical Characteristics
Dimensions (chassis)300x200x48mm / 11.8″ x 7.9″ x 1.9″ (WxLxH Dimensions do no include protruding parts)
Weight 3.5kg / 7.72lbs
Power Specifications
Power input (configurable, Based on label on bottom of chassis)220-230V 50/60Hz – Fuse spec : 2A SB 5x20mm
110-115V 50/60Hz – Fuse spec : 4A SB 5x20mm
Power Consumption20W
Accessories
Other included itemsPower Cable (USA ONLY) x1
USB Cable x1
Other Notes:
• Functions include: Auto Input Selection – LED indicator lights for each sample rate type as well as for input selection.
• Cyan 2 does not have buttons or remote control.
Dec 9, 2023 at 10:13 AM Post #2 of 806
If anyone has a chance to hear the Cyan2, please post impressions.
At $1,200, it looks like a solid competitor to the Merason Frerot, Soekris 2541, Audio-GD R1-NOS, etc. R2R DACs from $1,000-$1,500.
Dec 9, 2023 at 10:41 AM Post #3 of 806
Hmm, just as I was pretty much settled on the Audio-GD R-1 NOS for my next upgrade... Interesting 🤔
Dec 9, 2023 at 11:41 AM Post #4 of 806
Me too! Was being swayed toward the MHDT Orchid, but it has a tube, and my setup requires it be in a tight space, so that worries me.
Dec 9, 2023 at 1:56 PM Post #5 of 806
I might be completely blind, but I can't find an official Holo Audio website?
Dec 9, 2023 at 2:22 PM Post #8 of 806
Well, that's odd, isn't it? Why does a (relatively) high-end brand like that, not have a official website?
Imo that's a bit of a "turn off" :/
Dec 9, 2023 at 6:18 PM Post #10 of 806
Interesting, will keeping an eye on the reviews of this one.
Dec 13, 2023 at 7:15 AM Post #12 of 806
Dec 13, 2023 at 11:33 AM Post #14 of 806
One simple question, how to turn the unit off considering you have stacked it with other equipment and you really don't want to or it's almost impossible to reach to the back of the unit. :thinking:
Dec 13, 2023 at 1:19 PM Post #15 of 806
I believe kitsune is one of their distributors
Yeah, I think you are right, reading the about section makes me believe the same.
