holden4th
I'm assuming, I could be wrong, that bass is important to you as you seemed to like the Beats. If that is the case, then your first listen to the IE80s will probably convince you that you made the right decision but time will tell.
You've had all sorts of opinions thrown at you from the 14 posts so far and while many of them say look elsewhere they don't say where to look. I own a pair of the IE80s so I can speak from experience. I've also heard other iems in the price range. I listen to music that includes dubstep, trance, rock, jazz, chamber, solo piano and orchestral. Nobody has asked you what sort of music you like to listen to. This does matter with a lot of iems.
Some posters are implying that as the IE80s are no longer 'top tier' they don't sound so good. The logic of that astonishes me and who said you wanted top tier anyway? So start with what your instinct tells you - the IE80s. The IE80 is an extremely good all-rounder with a strong but detailed bass, an excellent midrange and clear treble. It also has the best soundstage of any IEM that I've heard and this is one thing that really makes them shine. One small caveat. Do yourself a favour and look past the ear tips that Sennheiser provide as they are not very good. The best I've found are Auvio hybrids which can be be picked up for about $5 for two pairs from any Radio Shack outlet or from their online store. The increased clarity they give you is unbelievable for what is a simple $2.50 upgrade.
If, at the end of the day they don't so the job for you, sell them on and try something else. This, unfortunately is the nature of the game when seeking out a really good iem.
