Hello, my name is Struan and I’ve been looking into getting into high quality audio. I’ve done quite a bit of research on what to get (mostly just debating whether to get the DT770s or the DT990s) but I’m still undecided on what amp to get. Here’s the rundown:
What I’m Going To Get:
I understand to properly run 80 or 250 (whichever one I get) ohm headphones I need an amp to really get the most out of them.
There was a couple of options I’ve been looking at, including:
Thank you for reading my post, I would be incredibly grateful for any help yous could give me!
- DT 990s (likely 80ohm, although I may get the 250ohm depending on what amp I get. Again, subject to change if I’m swayed by the DT770s)
- The Audio technica AT-LP60XBT. I chose this record player as I heard it was a good starter record player, and I wanted one which wouldn’t damage my records
- The FiiO E10K
- The Schiit Fulla
- The Schiit Magni+
