Mid high, i heard 2k daps that dont play like the dc elite in terms of tonalityIn term of sound, Dc elite can compete with some mid level DAPs.
IBasso DC-Elite . . . The no compromise DAC/AMP with a true Stepped Attenuator
- Thread starter Paul - iBasso
SQ13
- Feb 25, 2017
does DC-Elite has a line out? couldnt find any info on it
FooFighter
The answer is nodoes DC-Elite has a line out? couldnt find any info on it
Tell me, what are these files for?
iBasso UAC App for DC Series Version 1.6.8 December 13, 2023 (7.23M)
USB-DAC Win OS Driver for DC Elite, November 28, 2023, (4.93M)
Paul - iBasso
Sponsor: iBasso
I am glad you are enjoying the DC-Elite. It is, after all, all about the music! :^)I recently received this little green miracle, it sounds amazing with Enigmas, I didn’t even expect that it sounds at the level of expensive DAPs.
But it needs power from a power bank, with additional power it sounds great.
Stay updated on iBasso at their sponsor profile on Head-Fi.
- Oct 6, 2013
Yeah, but the music on the better gear is more enjoyable
FooFighter
Anyone tried the Y cable with a stationary USB charger and if yes will a female to female USB-C adapter work to get it connected using a standard usb C cable as extension?
Yes a female to female usb-c connector works.
Andystereo
Hi! just a question. I try to look in this thread but I still don't understand one thing.
I have Fiio KA17, i can activate with a button Desktop Mode. With Desktop mode, the phone battery drops fast, but i know.
This DC-Elite how works?
On request, can it take extra power from the phone?
Or is always necessary a powerbank? thank you!
(i think is a good upgrade for me, but i don't want use powerbank )
jamato8
It works fine straight from a phone but why use up the phone battery if you can add a small power bank but if one isn't desired, you don't need to use it.Hi! just a question. I try to look in this thread but I still don't understand one thing.
What is the correct voltage? Some power supplies or power banks generate from 4.9 to 5.3V. What is better to choose? Does it matter? - @Paul - iBasso can you help a little here?I recently received this little green miracle, it sounds amazing with Enigmas, I didn’t even expect that it sounds at the level of expensive DAPs.
Tthe adapters in the last photos (female C to C and A to C and 360` C to C) turned out to be very useful for me in organizing cables on the desk, when the elite is standing vertically it is very easy to adjust the volume)Anyone tried the Y cable with a stationary USB charger and if yes will a female to female USB-C adapter work to get it connected using a standard usb C cable as extension?
I think 5.3Volt is betterWhat is the correct voltage? Some power supplies or power banks generate from 4.9 to 5.3V. What is better to choose? Does it matter?
My power bank produces 5 V / 3A
Andystereo
(I apologize for my English, and if I use other DAC's brands to make myself better understood)It works fine straight from a phone but why use up the phone battery if you can add a small power bank but if one isn't desired, you don't need to use it.
This iBasso DC-Elite, or i think product like iFi Go Bar Kensei, are little product, with nothing (no BT, no battery...) is a DAC with important price! so i think work amazing for take music from the phone and put in my headphones in the best way possible!
In my mind, if i have to add extra battery, i take another product... Fiio Q7, Q15, Gryphon, X05Pro...
Of course, i look with KA17, is very confort possibility to put USB and don't drain battery on my phone!
but in my case I'm sure I would use it 80% of the time without extra power, that's why I asked the question above
I think is a best product for me...
