In the same boat. Really happy with it. Though I’d be lying if I said I wasn’t enticed by the PB5 to pair it with, especially for full size headphonesI'm still very happy with my 300MAX SS. I have no urge to "upgrade" to the 320MAX, especially given the annoying steps in the volume control of the latter. Now all we need is a firmware update to fix the ultimate mode on the 300MAX.
iBasso DX300 MAX Dual AK4499 Snapdragon 660 Octa-Core 6GB RAM 128GB ROM NEW Firmware: 2.02Available.
- Thread starter Paul - iBasso
I still have C9. You no longer have that? Not that I’m using the C9 with the MAX by the way. I use the MAX almost exclusively with IEMs and it has plenty of power for that.In the same boat. Really happy with it. Though I’d be lying if I said I wasn’t enticed by the PB5 to pair it with, especially for full size headphones
Edit: I see that PB5 also has a stepped attenuator. Nothing beats the smooth volume control of the 300 MAX.
If there are any experiences with PB5 and the 3max SS, plse share
I’m already in contact with Paul…
jamato8
For sound quality the stepped attenuator does.I still have C9. You no longer have that? Not that I’m using the C9 with the MAX by the way. I use the MAX almost exclusively with IEMs and it has plenty of power for that.
In theory, I am sure that is the case. Unfortunately in practice it does not work for me. I change volume all the time while listening, and the stepped attenuators are either not precise enough for volume control and/or produce jarring noises between steps. For users who set the volume once and then leave it alone this is less of an issue.For sound quality the stepped attenuator does.
That would be me. I hate fussing with the volume dial.In theory, I am sure that is the case. Unfortunately in practice it does not work for me. I change volume all the time while listening, and the stepped attenuators are either not precise enough for volume control and/or produce jarring noises between steps. For users who set the volume once and then leave it alone this is less of an issue.
WarrenS
Instead of using the line out on the 300MAX, I have just tried the 4.4 headphone out instead and set the volume on the PB5 to three quarters.
Works perfect with no perceptible changes in sound quality and volume control is now done on the 300MAX. Problem solved
Hey guys, if anyone wants a mint DX300 MAX for a crazy price, hit me up here: https://www.head-fi.org/classifieds/ibasso-dx300-max-mint-with-extras-big-price-drop.59704/
Further discount for anyone who mentions they saw my ad on this thread.
DAPpower
Thanks to @gLer I now own a DX300 MAX
I have yet to receive my unit but I have some general questions,
1. For some reason I can't find information on the micro-SD card capacity, is it 2TB or just 1TB? My library local library on my PC is a bit over 1TB so i can buy a 2TB one if I can find one on Amazon. Last I've heard, android doesn't play very nice with 2TB micro sd cards.
2. I haven't followed this thread much as I owned a few standard DX300s and DX320s but after all the latest firmware updates, which is still the preferred firmware version for the DX300 MAX?
3. I'm planning to send my DX300 MAX SS to Steve at NPAudio for the EXN mod, for those of you who still have your modded units, what are some of the major changes you noticed after all this time of burn in using those swapped capacitors?
Thanks!
Thanks!
jamato8
It will use a 2TB card. All of the ibasso daps will.Thanks to @gLer I now own a DX300 MAX
Thanks!
DAPpower
Thanks!, would a 1.5TB card also work?
jamato8
Why not? Everything up to and including 2TB.Thanks!, would a 1.5TB card also work?
Infoseeker
Thanks!
For number 3, I got mine modded by NPaudio.
It was overall beneficial, but for some there was a single con that can be a deal breaker. Enough so for alot of people that tried it with me.
It gives it a bit of lower treble glare/grain, where there was absolutely none in the SS version before that. You get a little, but from 0 to something can be considered a big change.
I wrote it in this post:
https://www.head-fi.org/threads/iba...w-firmware-2-02available.958400/post-17018344
DAPpower
Thanks a lot for that, do you think this type lower treble glare is headphone dependent? I'm planning on using my ZMF Calderas and HD650 with the 3MAX so they could synergize a bit differently than your Focal Utopia.
Perhaps I can ask steve to address this issue with the lower treble and perhaps he can make some adjustments to the mod.
Thanks for the insight though.
DAPpower
By the way, my 1.5TB SanDisk Ultra micro sd card (they currently have a sale for it on Amazon) just arrived, should I keep it in exFAT format or should I format it to FAT32?
Thanks!
Thanks!
Total: 14 (members: 0, guests: 14)
