So you settled on using your phone as source?
Ibasso PB5 the next dedicated portable Amplifier
- Thread starter Whitigir
CharlyBrown
For the time being, yes. I had some doubts at first because I don’t want to be disturbed by notifications nor distracted by any apps while listening to music. I just made a very simple shortcut automation: activate flight mode (cell reception off, wifi on), mute all notifications. Regarding apps, I try to improve my mindset not to open anything besides the music app. It works out well so far and if I can’t handle it right in the long run, I will probably buy the iBasso DX260 and connect it via Coax to the D16.So you settled on using your phone as source?
Paul - iBasso
Sponsor: iBasso
I am very glad you are enjoying the combination. It really is meant to be punctuation on sound and the enjoyment of music. It is meant to decrease stress and increase the pleasure of sound.After receiving D16/PB5 and doing some critical listening and comparing, I sold the SP3000.
I loved the A&K but now somehow relieved that I don’t need a DAP anymore and I have so much versatility now with my amps.
Stay updated on iBasso at their sponsor profile on Head-Fi.
CharlyBrown
Thanks for your feedback and I do so I think you nailed it with this combination D16/PB5, offering transportability paired with summit-fi sound quality and versatility. Great job!I am very glad you are enjoying the combination. It really is meant to be punctuation on sound and the enjoyment of music. It is meant to decrease stress and increase the pleasure of sound.
- Oct 6, 2013
Now, try to add to this combo iBasso's own 3T-154 IEMs I just covered these little budget gems in my review. including many different pair-up examples with various iBasso and other sources.
Dsnuts
- Jun 20, 2011
Any you guys looking for an upgraded interconnect for your PB5. I can say this customized Penon Totem interconnect is a clear upgrade. I am willing to bet it will be an upgrade from whatever you are using. Cus it is made of this stuff.
This cable material so happens to be Penons flagship Totem material which shown in above graphic. These make a clear difference vs the stock included interconnect Ibasso has included. Better dynamics, more body to the sounds, better enhancement of stage elements. All from this interconnect. This interconnect is using modular plugs which means I can change the plugs to palladium plated plug, Rhodium plated plug or OFC. All of which Penon sells. If your interested in getting yourself one. You can message Penon and they can make one for you. Their standard Totem interconnect is a bit too short so you will need to do a custom order. Send them a email if your interested and they can make one for you.
- Jan 15, 2015
What length is your Totem interconnect (in the photo)?
Dsnuts
- Jun 20, 2011
It is roughly 5 inches. I have another one I got made longer at 8 inches. I initially thought I needed a bit longer one so I had that 8 inch version made but then Penon suggested the slightly shorter version with modular ends so I got that too. The great idea about the modular ends is that not only can I use Penons custom plugs which are all 3 upgrades vs standard gold plated copper plugs but I can use single ended plugs for my older portable amps as well.What length is your Totem interconnect (in the photo)?
- Jan 15, 2015
Did you ask Penon to skip the black paracord? I believe Totem cable / interconnect is covered in black paracord (which is a shame, because your interconnect is so much nicer looking!)It is roughly 5 inches. I have another one I got made longer at 8 inches. I initially thought I needed a bit longer one so I had that 8 inch version made but then Penon suggested the slightly shorter version with modular ends so I got that too. The great idea about the modular ends is that not only can I use Penons custom plugs which are all 3 upgrades vs standard gold plated copper plugs but I can use single ended plugs for my older portable amps as well.
Dsnuts
- Jun 20, 2011
This newer version is all white vs the cloth covered version. I agree I like this new white one better.
RONJA MESCO
not necessarily...often I pick up the Oriolus BA300s portable amps and they dont color the sound in my rigs...because with tubes you will always get a coloration of sound, which i dont like. i am into flat neutral sound.
sofastreamer
- Dec 14, 2007
did a fast google search for reviews, opened three randomly and scrolled to the sound sections. all three stated that the Oriolus is not neutral, adds warmth and enhances the upper bass and mid bass response. didnt hear it my self though. on the other hand, why would you use tubes if not for getting a warmer sound signature?not necessarily...often I pick up the Oriolus BA300s portable amps and they dont color the sound in my rigs...
I have the 320 max and pb5. I’m wondering if I should get the d16 also? How would you describe the difference adding it to the stack?I finally found away to carry this whole stack without removing IC cables
- Oct 14, 2013
It depends for iems or headphones ? For iems, I think it gives a bit too much of the warmth together with the more dynamic punchiness, it may be too much for some people. IMO, if I use iems, I use it directly from D16. Unless I use headphones which is most of my use case, I pair with D16 for more dynamic prowess, better staging, layerings and cues of positioning. The tube timbres and the warmth comes with it. Best to pair with more neutral phones.I have the 320 max and pb5. I’m wondering if I should get the d16 also? How would you describe the difference adding it to the stack?
