Here is the Brimar 'Footscray' (made at the Standard Telephone & Cable Ltd Foots Cray plant in 1956). Langrex currently has 247 of them:
Listened this evening - finally - to the 12AT7 Brimar (purchased from Langrex) that has been sat on my shelf since October 2022.
Wow!
I swapped out a Brimar 'Red' 12AX7 purchased at the same time from Langrex, at more than twice the price.
In my set up/ears, the 12AT7 brings more than marginal improvements.
Noticeably, the tonal balance is much more balanced across the spectrum from low > mid > high frequencies. Despite the change in gain, listening volume on the pot is broadly positioned the same but with audible improvements in dynamics. I'm uncertain on this (after just one listening session) but if pressed I would say that the leading edge of transients slightly loses clarity versus the Brimar 12AX7 but detail is - if anything - improved whilst retaining fantastic timbre and texture.
I should state that I'm using new production tubes in the power section (Psvane CV181-T-MII) that have plenty of hours since October 2022.
My HP8 is also a Signature Edition with Mundorf caps.
I should also own up that I disagree with David Shaw regarding the effect of tube rolling in the HP8. Although my experience is limited, the first time - after about 24 months of use - that I swapped out the stock Treasure CV181s and EH 12AX7 it was like making a dramatic turn on tone controls; a radical change (not for the better).
Regarding the 12AT7, I should also mention that I am listening to wholly analogue chain. My cartridge (Dynavector DV XX2 MkII) is fairly low output and my phono stage always felt compromised with the either 60db or 70db gain options into the 12AX7. Conversely, 60db into the 12AT7 appears to have great synergy. On this basis, I make no generalist claims that 12AT7s improve on 12AX7s. Moreover, I'm listening on HD800S - soundstage and dynamics start from a great place; it is texture and tonality that is relied upon elsewhere in the chain.
As an aside, for about 18 months I have had an Icon Audio Stereo 30SE as my integrated in my speaker set up - I have been over the moon with it!
