Only seeing them for 500, which is a little more than I am wanting to pay.your tracks play very cool with xenns mangird top . I was recommended to buy them here on the forum. the price was 400 at the sale of 11.11 on AliExpress.
IEM for metal music and hard rock - ultimate solution
- Thread starter Mmurin
b510
then try to pay attention to 7 hertz timelessЯ бачу їх лише за 500, що є трохи більше, ніж я хочу заплатити.
b510
good day everyone suggest a cable for xenns mangird top which a little high frequencies will be removed. on some tracks, you can hear the sound of broken glass and sand in your ears. at this moment, all recommendations have converged on EPZ DP12.
Neithan
What tips are you using?good day everyone suggest a cable for xenns mangird top which a little high frequencies will be removed. on some tracks, you can hear the sound of broken glass and sand in your ears. at this moment, all recommendations have converged on EPZ DP12.
b510
xenns mangird topЯкі поради ви використовуєте?
Neithan
The ones that came with the IEM, correct? I didn't had any problem with them but I end up changing them for the Divinus Velvet... Maybe try those.xenns mangird top
Regarding the cable I'm using the NICEHCK Maple Flagship. I didn't felt any significant change in terms of the sound... But to give you a more correct feedback I would need to go back and do some A/B testing
b510
Thanks for the advice. I will order them tooThe ones that came with the IEM, correct? I didn't had any problem with them but I end up changing them for the Divinus Velvet... Maybe try those.
Hi, can you tell me more about that iem? Im a fan of psb headphones, had m4u 2, 4, 8, 8mk2 and wondering how those new twe are PSB has so little press coverage...Canadian company PSB recently came out with their true wireless microplanar IEMs. I blind purchased them without any review cuz I love full size planars. Boy do they rock. Highly recommend, the treble extension is fantastic. Dual driver so bass hits pretty well too, but not muddy.
Rockin_Zombie
They are fantastic, so simple and great sounding. I am listening to them more than I expected. They are also IPX rated so they have become my running buds as well. More comfortable than airpods, define more audiophile sounding than airpods. I think more IEMs should try this planar and dynamic dual driver combo. The bass and highs are crisp. Vocals are slightly recessed due to their room feel tuning, but gives you a decent sound stage. For the price they are a no brainer. I am so tempted to get the M4U 9s as well.Hi, can you tell me more about that iem? Im a fan of psb headphones, had m4u 2, 4, 8, 8mk2 and wondering how those new twe are PSB has so little press coverage...
The firmware is a little slow, it take a second for the buds to turn off after you put them back in the case. The first couple of times they kept playing music cuz I closed the flap before they turned off lol, but you get used to it. The lights blink when they turn off so not a big deal. Same is true for turning on, takes a second. If you remove them from the case before turning on, you will have to turn them on manually by long pressing. Minor annoyances that are consistent so you get used to it. Worth it for the amazing sound.
Hi!
I want to buy an IEM from the 350$ price range.
I've seen Aful Performer 8.
I listen principally thrash metal, speed-heavy and punk.
redrol
You want something with a ton of midbass which means not a lot of chifi.
Hello, metalheads. I recently bought my first iem, moondrop variations. The sound is not very good yet. Clean, but not enough bass. Now I want to buy a dac for an iPhone. Please advise a good option for extreme metal
redrol
Im actually retuning variations for metal. Well I did it. Its super good now. Running the DD full range with no midscoop.
MudEnjoyer
Questyle M15i is your best bet. Sell Variations… it makes the drum kit sound as if they were playing with chopsticks. Overdone guitars. Zero bass texture just woofer memes. Worst IEM I’ve heard for metal.Hello, metalheads. I recently bought my first iem, moondrop variations. The sound is not very good yet. Clean, but not enough bass. Now I want to buy a dac for an iPhone. Please advise a good option for extreme metal
Hearing lotta good things about Ziigaat Doscinco. I’ve ordered a pair, will report after the honeymoon phase.Hi!
