- Mar 20, 2013
Good to hear,already dear
182819
Please reach out in a PM if you do not get a satisfactory resolution.
Cheers!!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
182819
Thank you/ Waiting for ticked-answer for my issue.Please reach out in a PM if you do not get a satisfactory resolution.
Cheers!!
I don't see any reason why repair or replacement wouldn't take place in the case of a problem like this. The best bet is to inform support as to the issue and go through the support system to obtain service.I really like this little device but the volume control is broken. Sometimes it works fine and a lot of other times it does not. Does not register volume changes when turning the dial, then you'll randomly get a HUGE volume jump. The knob is a great interface, can use it without even looking at the device, but it doesn't work right.
I bought this a few months ago from Bloom - will iFi replace this under warranty?
try liquid oil under pressure and also reset to factory settings - it helped meI really like this little device but the volume control is broken. Sometimes it works fine and a lot of other times it does not. Does not register volume changes when turning the dial, then you'll randomly get a HUGE volume jump. The knob is a great interface, can use it without even looking at the device, but it doesn't work right.
Mine started doing exactly this, my unit was just out of warranty, after carefully disassembling, turned out to be a dry soldier joint on the smd rotary encoder (volume control), a quick re-flow with some decent leaded solder and not had a problem since (6 months ago)I really like this little device but the volume control is broken. Sometimes it works fine and a lot of other times it does not. Does not register volume changes when turning the dial, then you'll randomly get a HUGE volume jump. The knob is a great interface, can use it without even looking at the device, but it doesn't work right.
Specs please....I accidentally ran my spare Go Blu through the laundry. After letting it sit and dry for a few days, it works flawlessly, still.
Incredible.
Specs please....
temp, wash cycle type, duration, anti crease etc ?
This is why, despite the huge amounts of hatred Apple got for it, they used lightning connectors and tried to certify chargers.Finally received my unit back after the second battery swelling. Thanks to Liam from customer support
who went above and beyond. We will see how long this battery lasts. Will be very careful when charging. Avoid any phone charger even if it slow charging 5 output volts.
There are absolute trash chargers and cables on the market which damage devices. Glad they fixed it up and a shame you were a victim of some shoddy engineering on whoever built such a bad phone charger.
That's what I call cleaning the volume knobI accidentally ran my spare Go Blu through the laundry. After letting it sit and dry for a few days, it works flawlessly, still.
Incredible.
