- Mar 20, 2013
Setting the volume in Roon Device setup should allow you DSP volume if I am correct, then use the volume control in Roon.greetings
i hooked my ifi pro to my home system amp, my home system amp has no remote control
so i tried using the ifi as dac preamp and setting my volume amp on roon at 80% volume ( using ifi also as a streamer )
but i found the volume steps on ifi was not doing it for, sometimes moving the volume on ifi as preamp gave me too much volume
so i wanted to revert back to using ifi just as dac, and control the volume via roon, but somehow the volume ( device volume ) just goes either no volume or it will dial in full volume which is weird
any help with roon to control volume using ifi pro just as a dac
or if there is a more ideal way to have good voume adjustment
@iFi audio
Hope that helps
Do you not have the remote for the unit?
If so set Roon to fixed and control preamp volume using that and adjust rotary setting on the back of DAC to variable.
HF Var...
Cheers!!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
