Fantastic! Look forward to your feedback on hookup to iESL speakers input.
I’m looking at a preloved 2004 SE84CS Zen. With its basic design remains, i hope it doesn’t differ too much to latest ufo2.
The speaker to 4-pin XLR look like this, which I saw locally, as alternative to iESL bal input
ok I have just tested this and it is extremely surprising - and may have wider interest here for anyone who may be thinking about connecting a tube amp into the iESL (TLDR; it works)
I've just tested 3 things in parallel - both with the 007mk1 and X9000k (mostly with the latter):
(1) Mjolnir Carbon on its own - just as a reference point (with which I'm very familiar, and like a lot)
(2) iFi - powered by my Simaudio MOON 330A amplifier (spec'ed 125W at 8 ohm)
(3) iFi - powered by Decware Taboo SE84TS+ (spec'ed 8W, at 8 ohm afaik) + an OTL tube pre
The surprise - all provided about equal power and headroom.
(1) and (3) provided a classic contrast of SS vs. Tube amping, with the Carbon offering fast attack and a crisp voicing, and the Decware providing a hologrpahic sweet tube voicing.
In fact, this may be my favourite X9K setup right this second as I listen to it for the first time. It's super fresh, so I may revert or change my view naturally but, off the cuff, it's super viable and potentially great.
Note - I used the XLR in, based on iFi's direct input above that the speaker taps and 4-pin XLR are the exact same balanced inputs ino the iFi with just a change in convenience factor which plugs are used (I had a speaker-to-XLR cable on my Decware, with another XLR-to-XLR extension cable I added to it to reach the iESL, which let me quickly conenct and test; this cable setup can be further improved)
(note - if you are buying an even older Taboo than my model, check the wattage. I recall they made a switch from 2 watts to 6 watts at some point in their history prior to my (already rather old) model, and I think the lower wattage would not work)
