iFi Audio Zen Dac 3... Plug In, World Out!
Apr 24, 2024 at 10:58 PM Post #136 of 201
Not trying to argue, just politely putting forward a counterpoint.
Doesn’t audibly transparent mean that the analog output is absolute faithful to the digital input ? No, based on my understanding, ASR's defintion of "audibly transparent" is that if you are put under a "well controlled" objective, level-matched, double-blind, ABX testing environment, you cannot hear any difference if I change any equipment on the signal path. In their mind, DACs fall in that equipment category. i.e. If two DACs are having good measurements (e.g. SINAD is better than certain dB, etc...), you won't tell if I change the DAC as they should sound the same to you. In other words (I think), they mean a DAC would sound the same no matter it costs you $100 or 10k as long as they are "measured as audibly transparent as defined above"
If two different DACs do that with different internal components, the analog signal from both audibly transparent DACs will be identical and therefore the sound out of the connected amplifier will be identical, isn’t that literally the meaning of audibly transparent. With the definition of "audibly transparent" stated as above, my view is that "If two different DACs do that with different internal components, the analog signal from both audibly transparent (as defined above) DACs will NOT be identical"
Not being funny but it sounds like you are arguing essentially with the statement “two devices that sound the same will sound the same.” No, I think you take "perfectly re-construction of the original analogy signal" as the definition for "audibly transparent" as a based for your statement. If that is the case, I agreed with you. However, it is NOT their defintion. With their defintion I stated earlier, what I really mean is that "two devices that sound (i.e. reconstruct music) differently will sound (as you hear) differently" but, with ASR's view point, "audio signal reconstructed by two different but audibly trasnparent (based on their definition) DACs should sound (as you hear) the same to you". They further comment that "if you really hear any difference, it must be your brain is fooling you or you use a poorly designed filter for your DAC" <=== this sound an unfalsible claim, one of the characteristics of Pseudoscience - Wikipedia.
Extending that further, if two amplifiers are also audibly transparent won’t they sound they, by definition of audibly transparent, also sound the same ? So any combination of audibly transparent DAC and amplifier will sound the same. You are 100% correct but you have a dfferent defintion of "audibly transparent" than the one used by the people in ASR. Even with their defintion, based on their measurements alone, could it be enough to tell if two DACs are "audibly transparent"? i.e. Is good measurements values == "audibly transparent"? For me, my answer would be no. Actually they mis-used a well known term (Confirmation bias) in Psychology to support a lot of their pseudo science claims. I think a lot of people is already fooled by this mis-usage. Feel free to check if you know the term well too here ==> Do you see the same color? Why? (no-pseudo-science.blogspot.com)
I saw your visual comparisons. Isn’t that actually shooting down your own argument? You are literally showing how our senses can be fooled by other stimuli. In your examples it is vision that is fooled, in audio it is hearing that can be easily fooled or isn’t reliable. Our auditory system is an awful long way from infallible and isn’t a great judge if other stimuli are also introduced, that is just how we as humans function. Yes and no.. I wanted to show that our hearing can be easily fooled too. BUT my main point is "For a simple reporting-type question like 'do you see the same color?', do I have to say 'I don't see any difference' in order to conform with their group beliefs". I believe that if you report what you experience (i.e. see), you would probably say "No, I see they are different". What if someone keep telling you that "you see the same color"? My other arguement is that "I see they are different even if they should be the same. What if they are indeed slightly different? How can you guarantee that your 'audibly transparent(?)' DACs would not reconstruct audio signal outputs that is slighlty different???" <=== not sure if you think it makes sense. Please feel free to comment further on my blog.
Thanks a lot for your reply and I'm really sorry for my off-topic action earlier. I am not going to say any more than the above here (as this thread is for iFi). Please feel free to comment on my blog Do you see the same color? Why? (no-pseudo-science.blogspot.com) and discuss more there (I just included our discussion above there). Again, thanks for your reading of my writing. I think we need more people like you who have independent thinking. Cheers.
Back to iFi Zen DAC 3, it seems the DAC 3 is not available in China yet. I just checked TaoBo and I cannot find any (even from the "iFi Flagship store" <=== not sure if they are offical or not).
One more thing, I noticed two types of iPower:
Is the first one known as iPower 2? Just wondering what are the differences between them?
Apr 25, 2024 at 4:46 AM Post #137 of 201
No, his entire point is simply saying it goes both ways,
He literally ‘laughed’ at the notion that “audibly transparent” DACs would sound the same and labeled that misleading, I saw nothing about anything going both ways.
Let’s just leave it there, my query was to him and he prefers not to respond here and I have no interest in responding on his blog. Last time I tried to discuss anything with you, all you wanted to do was argue well beyond the premise of the question and I have no interest in going there again.
Apr 25, 2024 at 5:08 AM Post #138 of 201
Sorry, did you mean He = me = sunjam? Or you mean someone else?
If you mean me, I did reply clearly inside your quote. Did you see what I see? Or you see something differently??? :thinking: Have a look clearly but please stop here as I mentioned it was my bad that as it was off topic.
Apr 25, 2024 at 8:01 AM Post #139 of 201
Nope, my Mac isn’t in standby. As I mentioned, it stays on even when the USB C cable is disconnected, so I’m not sure what more I can do to see if it’s something to do with the computer. When it’s plugged in and nothing else is, it’s on. I can turn it off at the socket but thats a bit of a pain.
Ever figured it out? Mine stays on when connected to the external 5v power supply, but disconnected from usbc. Bit annoying having to manually disconnect it from power. Not sure if that's intended or just a design flaw. Surely there would have been a way to turn off the dac when disconnecting the usbc lead (or powering off the device it it connected to via usbc), despite the 5v power brick left connected. Maye something a firmware update could fix @iFi audio
Apr 25, 2024 at 8:45 AM Post #140 of 201
I am still awaiting a response regarding this, and also have a ZD3 arriving (hopefully) tomorrow, so I can do more of a deep dive with different computers, and laptops.
We will get to the bottom of it, and as soon as I get a response I will update this thread.
Cheers!!
Apr 25, 2024 at 8:47 AM Post #141 of 201
Cheers!!
Thank you. I tried it on my MacBook and windows pc. Both powered down with usb c plugged in and disconnected. The dac stays on regardless when external power is connected. As I said it's not the end of the world. Looking forward to your findings
Apr 25, 2024 at 8:50 AM Post #142 of 201
You're welcome!
Is this the same then as @faustus67 where the front lights are illuminated (not just the back) external power indicator?
We will get to the bottom of it and I am sure this is something that can be addressed.
Cheers!!
Apr 25, 2024 at 8:54 AM Post #143 of 201
You're welcome!
Cheers!!
Correct. Front light illuminated despite no usb c connection. Should be just s simple firmware fix where it cuts off the power when no signal incoming via usb c
Apr 25, 2024 at 8:57 AM Post #144 of 201
Thanks for confirming.
I agree and have passed on the relevant information to the tech folks.
Cheers!!
Apr 25, 2024 at 10:14 AM Post #145 of 201
This has been the case for every Zen DAC I’ve owned. I remember finding it annoying because the external power light was quite bright and would light up my desk when I went to bed.
Apr 25, 2024 at 12:09 PM Post #146 of 201
If the computer it is connected to is powered down (not standby) and everything is left connected the front lights go off after 30 seconds.
See my pictures on the previous page, this is true for Zen DAC V1,2 I am getting ZD3 tomorrow and will test the same.
Cheers!!
Apr 25, 2024 at 3:34 PM Post #147 of 201
Cheers!!
The front lights, yes, but I was talking about the rear "ext power" light. That stays on as long as the power is connected.
Apr 25, 2024 at 3:40 PM Post #148 of 201
Gotcha! This true that the little green light stays on its ext power indicator as you said.
Cheers!!
Apr 25, 2024 at 3:52 PM Post #150 of 201
I always put black electrical tape over stupid bright led's
I wouldn't call it "stupid bright" but Fun Tac works well for this as well, :beyersmile:
I also tend to be one of those that close my eyes when I lay down, That way there's no chance of seeing the monsters!!
:beerchug:
Cheers!!
