They have xDSD - portable balanced DAC / ampThat's too bad
If it's USB powered, it could be more portable. I hope they'll make a smaller 4.4mm balanced USB-powered DAC soon. or dual 3.5mm balanced would be great too.
iFi audio ZEN DAC - EISA Award Winner 'Best Value DAC 2020-21!
- Thread starter iFi audio
Baten
- Sep 13, 2012
is this unit USB powered???
Wow! I can't wait to use 4.4mm output with my laptop!
I thought it was confirmed to be working over USB, the barrel port is to override power input from USB to external source...That's too bad
USB = perfectly fine for powering it.
This superb hi-res USB DAC/headphone amp delivers a level of specification and performance that punches above its super-affordable price tag.
Compact enough to use as a USB DAC/amp on your work desk with your much-loved headphones.
Stylish enough to use in your home system as a USB DAC. Just add your favourite active speakers or amp.
@iFi audio can you confirm?
human bass
So, what is the price? Because it may very well be an affordable end game.
149eur at amazon.deSo, what is the price? Because it may very well be an affordable end game.
human bass
Damn, a balanced dac amp from a reputable company for 150? This is crazy cheap even for chinese standards.149eur at amazon.de
true... just bought an q5s for pc use.. but consider to get one of these too for this price...Damn, a balanced dac amp from a reputable company for 150? This is crazy cheap even for chinese standards.
Are the preouts muted when headphones are plugged in ?
- Mar 20, 2013
Will this work fine with ZEN DAC? Thanks
Yup, should work!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Jimi Zine
- Dec 12, 2014
Yup, should work!
and where can we get a balanced cable for speakers in the UK?
- Jan 15, 2015
Standard DC barrel connection.
It IS USB-powered! Briefly auditioned it at ZMFestivus couple weeks ago... Only cable going in was USB from a laptop!!
I have asked the iFi guys there whether it is battery powered, and they told me: No battery! USB powered
udesign48
@iFi audio Please make a smaller USB powered DAC with dual 3.5mm balanced outputs!
I think Sony PHA-3 is too expensive for that...
In my opinion, dual 3.5mm balanced output has the most amount of power and clarity. It beats 2.5mm balanced easily.
The choice of connectors, may it be 2.5mm TRRS, 4.4mm TRRRS, 3.5mm TRRS or dual 3.5mm TRS, has nothing to do with how much power any device can pump out, It is the headphone driving stage that determines the level of power (among other factors) at the end. You can easily make a 2.5mm TRRS outputs more power than any other connectors as long as you put a very powerful circuit behind it. Besides, dual 3.5mm TRS is a dead standard that even Sony has abandoned for 4.4mm TRRRS.
udesign48
That's not true. Check Pono player's dual 3.5mm output. It's still way better than anything I've heard so far. I think it's about time to see more affordable and portable dual 3.5mm balanced USB DACs.
You still missed the idea by a mile. Physical connector doesn't determine how much power the output is. It is the hardware behind the connector - all the resistors, capacitors and opamps alike, that determine how much power there is.
udesign48
Regardless, I haven't heard anything more powerful than Pono's dual 3.5mm balanced. I've listened to all kinds of DACs and DAPs including DX100, Sony ZX1, PHA-2, Onkyo DP-S10, LG V30, Antelope Zodiac DAC, Apogee Groove, Roland UM 10, etc. They don't sound any better than Pono's dual 3.5mm balanced output. If someone can implement that powerful dual 3.5mm balanced into a portable, USB-powered DAC, I'm buying it.
