iFi audio ZEN Stream - Streaming elevated to a higher plane
Jun 26, 2021 at 6:53 PM Post #31 of 5,874
Pretty Nice, up and running in under 5 minutes from box to desk! I have no idea what some reviewers are talking about not being able to get it set up. Roon, Spotify Connect, Tidal Connect, it was all right there as if I had it for months! More later!!
Congratulations!!!
Mine should be arriving tomorrow. If you are able to, can you see how to play local music (HDD/micro-SD card + adapter connected to the USB inout port) please? TIDAL should be fairly easy via TIDAL Connect. However, I have a micro-SD card loaded with my lossless music in an USB adapter and I really want to be able to play songs from it using the iFi Zen Stream.
Also, I'm hoping the lights go out after a while as mine will be in a bedroom.
Jun 26, 2021 at 6:57 PM Post #32 of 5,874
Congratulations!!!
I'm pretty sure those lights stay on but I'm gonna look into the menu for you.
I do have a drive with music on it so I will try to get to that too, but from what I saw it's just plug the disk stick whatever into the top USB and scan liked any other music steamer, or media player.
The menu on your browser looks exactly like volumio, if you've seen that
Jun 26, 2021 at 6:59 PM Post #33 of 5,874
Quick screenshot for you...
Jun 26, 2021 at 7:13 PM Post #34 of 5,874
Congratulations!!!
Didn't realize it but the lights can be turned on and off with the button on the far right, it's a dual function button! So your good, no lights on the front when pressed!
Jun 26, 2021 at 7:21 PM Post #35 of 5,874
So you just plug you SSD, HD, USB stick into the upper USB 3.0 slot, in the menu you'll see sources, scan your drive done the music shows up in my library... Screenshot of the only external I had handy, lol!
Jun 26, 2021 at 7:43 PM Post #36 of 5,874
Yeah, I used Volumio for a short while last year so have a little familiarity with it.
Jun 27, 2021 at 9:07 AM Post #39 of 5,874
Do you guys have any experience with Roon setup already?
Are there any print screens showing the Roon Signal Path when the Zen Stream is used somewhere between your source (let's say Intel NUK on ROCK) and a DAC?
Any improvement in sound quality over a direct usb connection from your source (PC, NUC on ROCK, etc.) to your DAC?
Basically I would have 2 scenarios for ZEN Stream:
- desktop application: put it between my Intel NUC on ROCK and my DAC (via Ethernet connection);
- remote application: use it as a wireless streamer only for my iDSD Diablo when needed.
Both scenarios require Roon compatibility.
Thanks.
Jun 27, 2021 at 9:34 AM Post #40 of 5,874
Thanks.
Just a quick reply, all I had to do with Roon is just enabled it liked any other device, sorry but those is all over got time for right
now, more later...
Jun 27, 2021 at 10:04 AM Post #42 of 5,874
Is this already Roon Ready? Or is certification still pending? I checked Roon site and no mention of the Stream yet…
Jun 27, 2021 at 10:12 AM Post #43 of 5,874
If you look on the iFI page for the ZStream it's had some wording for Roon, something like certification in the pipeline, but looks Roon Ready To my eyes, but who knows lol
Jun 27, 2021 at 10:16 AM Post #44 of 5,874
Quick snap of the Roon Audio Settings Menu..
Jun 27, 2021 at 10:16 AM Post #45 of 5,874
