stuck limo
Formerly with Light Harmonic/LH Labs
- Feb 6, 2016
I installed the GND after getting rare periodic hum in my setup. I have not experienced any hum after the install.
I did the same with my tube amp and it greatly reduced the background hum so a very good product.I installed the GND after getting rare periodic hum in my setup. I have not experienced any hum after the install.
It's periodic HUUUMMMMM. I don't need to take measurements to show that the rare HUUUMMMMM flooding my headphones isn't there or was replaced by " " (silence).@stuck limo @TheAbyss2022 I would like to see measurements that the hum has decreased.
The puritan 156 power conditioner lists for 1.8k and can probably be had for 1.5-1.7 if one asks for a deal.A question regarding power setup.
Currently running my gear from the wall with rather cheap shielded copper cables (around 100 eu per cable) and decided to upgrade to match Envy with May.
The idea is to get 3 supanova cables and ifi powerstation, which will result roughly in a 1.5-1.7k purchase. Which is a lot. To those who are more versed in the ways of power lol - are there any better solutions?
Niagara 1200 is another variant. I am just not sure if its worth the money, maybe should try the amazon stuff and return if there is zero difference, hm.The puritan 156 power conditioner lists for 1.8k and can probably be had for 1.5-1.7 if one asks for a deal.
It's supposedly way better than the iFi solution, even with your current cables.
I say supposedly since I haven't tried either.
I got my PS Audio stellar p3 Power plant used for 1.8k and I assume It's also superior to the iFi solution, however you'd have to go used
From what I read the Puritan is way better than the lower Niagara stuffNiagara 1200 is another variant. I am just not sure if its worth the money, maybe should try the amazon stuff and return if there is zero difference, hm.
Way blacker background, seemingly better subbass extension, more clarityWill check, thx! What change did you experience with your Envy back in the day?
