IMR Audio : Sonic Adventures & Impressions
Future of IMR threads
  • Single thread for all models.
    Votes: 8 47.1%
  • Multiple threads for each model.
    Votes: 9 52.9%
  • Total voters
    17
  • Poll closed .
May 11, 2024 at 12:06 PM Post #18,076 of 18,272
I don't suppose any of you have Zion news? Supposed to have done the rebuilds and shipped in January so they must be lost...
Sorry to hear that you haven't received your Zion. I don't think anyone else has this either. I think you should keep asking for refund through email. You can try IMR facebook as well for your refund status. Alternatively, if there is no scope for refund, then check IMR ebay site and see if you can manage to cut down your losses for any available stock.
May 11, 2024 at 5:46 PM Post #18,077 of 18,272
@mekap has DC-Elite and Enigma+. Try some used Ak sp1000, I think it may pair up well. Sure Hiby r8 II is an ultimate solution, but it's pretty expensive.
On Titan this piece smashes!
This reminds me of the following . . . for those needful low end slam times :wink:
Whilst Im at it
Sohn has one of the best Audiophile albums in this genre (IMO)
May 11, 2024 at 7:30 PM Post #18,078 of 18,272
Very nice music selection.
Also thanks for the recommendations about sources.
By the way, I remembered I also had a Fiio K3 usb DAC/AMP. Listening to it with Titan, it is not bad at all. Full bodied midrange, weighty with great imaging.
I've also ordered a k17 to check out. I like that fact that it has also an independent power source of needed.
May 11, 2024 at 8:47 PM Post #18,080 of 18,272
Whilst Im at it
Seven nation army in this iteration is more on Glitch/Dubstep side, but it bass dropping well too
May 12, 2024 at 7:50 AM Post #18,081 of 18,272
:D I couldn't think of the terminology!
May 14, 2024 at 11:36 AM Post #18,082 of 18,272
How would you guys describe the stage of the Enigma/ Enigma+ (I assume the original lot were closed back) ?
Some how I feel Seraph has better stage ! Enigma doesnt feel as expansive as Seraph.
Do filters and cables alter stage ?
Any pointers if i can achieve a more expansive sound from the ENigma + ?
May 14, 2024 at 11:44 AM Post #18,083 of 18,272
3 dimensional stage with kind of layers. So not the largest but not even narrow for sure
May 14, 2024 at 1:35 PM Post #18,084 of 18,272
As you probably know, wide bore tips that sit more distal into the auditory canal rather than deeply inserted narrow ones, have an effect on sound stage (sense of wide space). Also the source can be definitive factor. I am not sure about cables.
I also confirm that Enigma does not recreate a wide soundstage though imaging (sense of place in space) is robust. Titan is better IMO with these traits.
BUT the exceptionally demarcated bass of Enigma gives a feeling of sound 'sculpting' which is soooo special.
May 14, 2024 at 4:53 PM Post #18,085 of 18,272
Well, Titans sound like it was Bob's work on mistakes regarding Avalon. Because as we mentioned here: after a burn in Avalon used to lose some treble. Here we've got all the richness of treble that audiophile may desire. At least from IMR community. Dynamic driver has an analogue like feedback similar to what we've got on Avalon, so slightly more tubish of a bit fuzzy, but with good body and impact. Enigmas have the DD closer for what they were on Astra ultraque - faster so they don't perceive that analogycal. I thought they would be more similar considering the same diameter, but I mistook.
Avalon are slightly more demanding regarding the amplification, I need to volume up a bit changing to them from Enigma.
So if somebody liked Avalon and wants something close but with even more bass extension and better/richer treble, this is your choice.
Enigma are clearly another generation and different approach. The transparency of the sound is the first thing that you hear after you pass from Titan. This makes enigma appear more open regarding their timbre. Overall they sound is more linear comparing to the V shaped predecessor. The bad point of this is that you need to have good quality audio or you'll be a victim of dirty flood. Avalon are more forgivable.
I'm sorry for the eventual mistakes
UPD. On titan there is some diaphragm crackle while you insert them into the ear. Fortunately Enigma lost this feature
Thanks @koledoff1986 for this opportunity
Another thing I forgot to mention. Titan comparing to enigma because of less forwarded mids result darker
May 14, 2024 at 4:56 PM Post #18,086 of 18,272
If anyone forgot .... Penon still has Seraph, Elan+, and Rah 2023. Sold out of BC. Whatever!
May 15, 2024 at 1:03 AM Post #18,087 of 18,272
Thank you . I will try wide bore tips. I agree Enigma has narrow stage as a result crowded imaging ?
May 15, 2024 at 1:22 AM Post #18,089 of 18,272
You know guys, I do see some discrepancy here in the descriptions. I am more on the side of @rottoman I believe than @paggio as Enigma is concerned. A decisive factor must be, apart from objective sound production by the IEM, the psychoacoustics component. That is, differences in our respective biases and interpretation of what we hear. And of course language differences and semantics as it is not always straightforward for all, what 'layers' or 'transparency' means, or other terms many of us use here. That is why I prefer 'real life metaphor descriptions' that relay meaning more easily of what anybody hears (like @paggio and @jon parker sometimes do).
May 15, 2024 at 4:38 AM Post #18,090 of 18,272
When I said layers I meant that sometimes there are kind of different levels into to the imagining sound stage and you can distinguish: determinate sound came from further or closer layer. Obviously not every track has kind of pricise and complex sounstage, but I noticed this ability into some songs I listened to.
