Inju
So after some more experiementing a few more items to note:
1. There are two usb c ports on the back of the unit. One is for the DAC and USB audio out function and the second is a charge port. The DAC/USB Audio out port DOES NOT seem to charge the unit, so if you have this in a permanent setup make sure you're using one cable to keep the unit charged and the second for your DAC/USB Audio out function.
2. If the batteries are completely drained, you can plug in the USB Charge cable and it will still power on the unit. In other words the charge capabilities are higher then the battery drain, which is a good thing.
In terms of sound quality, it sounds really good to me. Does anyone know how to record USB Audio directly into the PC, i.e. plug the device to a USB port on your PC and use Audacity to record the CD to your hard drive? If anyone has information on this please let me know. I will likely post in a separate forum on here more dedicated to that subject as well.
