Looks really interesting. I see mention of a microSD slot, but I do not see one either front or back? Does the software allow for searching either a network drive or SD card by something other than title... i.e by composer, artist, album artist, genre?With our EM line, we aim to offer an ideal all-in-one desktop solution for all headphone listeners. We started last year with the EM5 model, which packed a lot of features into a reasonably sized and very well priced package. Now we are pushing it further with the EM7, improving upon the EM5 in every single aspect, going for a High-End performance that will match any of the best Audiophile headphones.
Analog section of EM7 is designed around the flagship ESS DAC ES9038Pro, with its eight channels feeding a fully balanced amplifier, build on our proven OP+BUF architecture. This amplifier circuit was newly designed especially for EM7, matching the highly accurate and clean sound of the DAC, while providing strong power output for the most demanding headphones. Resulting in our best measuring and most powerful desktop DAC/AMP, offering up to 7W @ 32 Ohm // 1W @ 300 Ohm.
On the Streamer side, EM7 is running our closed and customized system, now build upon Android 10. Giving you access to a range of streaming services, local playback from MicroSD card or USB drives, DLNA, Airplay, NAS and even simple Bluetooth streaming. All run through our Android Global Lossless Output (AGLO) system, assuring the ideal audio performance from Android system. EM7 also switches to a faster Qualcomm Snapdragon 665 CPU, making for a significantly swifter system.
The most obvious part of the EM7 is its new tiltable display. Bigger 5.8-inch touch screen with 1080p resolution can be angled up to 60 degrees, allowing for an easy control no matter if it’s placed on a desk or on top of a Hi-Fi rack. And of course, there is always our Eddict player app, serving as a remote control for the local playback or as a complete screen mirroring, giving you access to all sections of EM7 directly from your phone.
Mixing both a streamer and a Hi-Fi DAC/AMP into one device can be tricky, but we took steps to limit any unwanted interference. DAC and amplifier are isolated from the Android section and we are utilizing an independent power supply for each, with a low-noise Noratel toroidal transformer for the Analog section and a high-quality switching power supply for the Android section.
EM7 is a truly versatile device, smoothly switching between its role as a high-end source for headphones, to a pure DAC with an optional pre-amplifier, to a digital source for your DACs with Coaxial, Optical or USB inputs. If you wish, you can even use it as a source for your Bluetooth headphones or speakers.
EM7 will be available on international markets in August, at MSRP of 2 099 USD/Euro.
Specification
Dimensions: 252 x 188 x 67.5 mm
Weight: 3.2kg
Display: 5.8-inch 1920*1080 IPS Touch screen
System: Based on Android 10, Closed and Customized
Hi-Res Support: Up to PCM 32bit / 768 kHz & DSD512
Bluetooth: Version 5.0, serving as both Receiver and transmitter
BT codec support: Receiver LDAC & SBC // Transmitter LDAC, aptX-HD, aptX, SBC
Wi-Fi: Dual band 2.4G & 5G
DAC: ESS ES9038Pro
Analog Section: OPA1611 based I/V conversion, OPA2211 based LPF, OPA2211+BD139+BD140 based Amplifier
Analog outputs: 4.4mm & XLR balanced, 3.5mm & 6.35mm Single-ended, with pair of RCA and XLR
Digital outputs: SPDIF Coaxial & Optical, USB Audio Output
Digital inputs: USB-B, Coaxial SPDIF & Optical, 2x USB port for USB drives, MicroSD card slot
Output power Single Ended: Up to 8.5V / 2.3W @ 32 Ohm // 9V / 270mW @ 300 Ohm
Output power Balanced: Up to 15V / 7W @ 32 Ohm // 18V / 1W @ 300 Ohm
Output Impedance: 1.2 Ohm SE // 2.4 Ohm BAL
Balanced THD+N: 0.0003%
Balanced Dynamic Range: 125 dB
Balanced SNR: 125 dB
Balanced Channel separation: 104dB
Introducing Shanling EM7 – High-End Desktop Streamer DAC/AMP
Modified
- Oct 26, 2016
Volumio is more affordable. Great SQ.Word. Latest streamers MUST be Roon ready, no exception!!!!
Please, Volumio!
Probably no. 9038 chip has 8 dac so 4XchannelLooks interesting. Two dac chips?
dadracer2
I'm not at all bothered about Roon, but more information on the control app would be of great interest. Are the WIFI aerials built in?
This thing looks oof! Really nice stuff. Looking forward to testing this unit soon with some killer headphones.
newworld666
Android 10 "close" .. does it mean ?
-> no PowerampEQ or Wavelet available ?
-> no apk installer for UAPP or Neutron Players ?
If so .. what about Parametric EQ ?
purk
- Sep 26, 2001
Love the tilted screen. I wish on my M30 and DMP-Z1 every day for that feature!
jamato8
Yes but getting the power to each chip, and true separation and caps for each chip etc., is what can make a different, regardless of how many dacs are in a chip, which are then paralleled.Probably no. 9038 chip has 8 dac so 4Xchannel
yes i knowYes but getting the power to each chip, and true separation and caps for each chip etc., is what can make a different, regardless of how many dacs are in a chip, which are then paralleled.
jamato8
I figured you did. To me, it is worth it. I look forward to impressions.yes i know
RONJA MESCO
I mean, for $2000, to me, this need to look alot better beyond the screen. It looks like a regular ol Xduoo amp with a screen to me. I just dont want this form factor for that much cashessh and it looks bland within my setup. The other big screen offerings from Shanling, Cayin, Sony and even Astell/ Kern look a bit higher tier than this. I mean, damn, at least give me a super nice turn knob on this at minimum.With our EM line, we aim to offer an ideal all-in-one desktop solution for all headphone listeners.
This may all be true, but I don't think I've ever seen a dual-9038Q2M dac that measures as well as a single 9038 Pro. And this tracks with my subjective impressions. The Pro is just a really, really good chip. Would a listener benefit from having two of 'em? Sure.Yes but getting the power to each chip, and true separation and caps for each chip etc., is what can make a different, regardless of how many dacs are in a chip, which are then paralleled.
jamato8
Right, so I am not sure of your point. Maybe I missed something. I thought they were using the 9038Pro. If the portable chip, then would have gone with the Pro chip.This may all be true, but I don't think I've ever seen a dual-9038Q2M dac that measures as well as a single 9038 Pro. And this tracks with my subjective impressions. The Pro is just a really, really good chip. Would a listener benefit from having two of 'em? Sure.
Ok, it does use the Pro chip, so inconsequential regarding the Q2M, since it is not in the mix.
My point is that two quad dacs is not necessarily better than one octo.
jamato8
Right. Wouldn't say they were,. I was referring to using two 9038Pros, not using the portable dac chip.My point is that two quad dacs is not necessarily better than one octo.
