SGarfinkle
@Shanling Does development have any ideas for a workaround (to say nothing of fix)? Roon support suggested disabling USB Audio Routing, but that didn't make any difference (not that I expected it would).
So far no update on the Roon ARC issue.@Shanling Does development have any ideas for a workaround (to say nothing of fix)? Roon support suggested disabling USB Audio Routing, but that didn't make any difference (not that I expected it would).
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
The Roon main app is working on current firmware. For Roon ARC, software team is still working on fix.Month 2 with broken Roon. Since they can clearly reproduce it and it's on ALL your Snapdragon models, I would have expected this to be fixed by now.
Yes, the discussion is about Roon Arc, not Roon remote. Roon Remote is a lot more annoying to use anywhere but in the house. It only works if I install OpenVPN on the M6U and turn on the home VPN server.The Roon main app is working on current firmware. For Roon ARC, software team is still working on fix.
I'm sure you'll love it (as long as you don't need Roon ARC)! Mine took just a few minutes to update, IIRC....how long does it take for the update to complete?
Many thanks for the prompt response. I don't use Roon.I'm sure you'll love it (as long as you don't need Roon ARC)! Mine took just a few minutes to update, IIRC.
That's always nervewracking. MY nonprofessional guess is that you're probably OK to turn it off as it probably isn't actually doing anything. Something similar happened to me (see earlier in this thread) where I accidentally tried to use the M3 Ultra firmware to do the update. But...it's always a crapshoot, sadly.Okay, its been running for over an hour now, just says on screen "Updating now, please do not turn off....."
Should I perform a restart?
Ha ha, yes that correct regarding "nerve-racking!"That's always nervewracking. MY nonprofessional guess is that you're probably OK to turn it off as it probably isn't actually doing anything. Something similar happened to me (see earlier in this thread) where I accidentally tried to use the M3 Ultra firmware to do the update. But...it's always a crapshoot, sadly.
I did not hear a difference in "Prime Mode" vs. normal Android mode...M6U is still impressing regarding sound quality. I always use "Prime Mode" when listening and turn off Bluetooth and WiFi. Bass and reverb are excellent imo and the highs are smooth and detailed. Hi-hats come through clearly when there and Vocals are very real to me. Using Focal Celestee for context. Its a very pleasurable listening experience and I can/could easily listen for hours without any fatigue
