All,
Thanks for all your posts - much appreciated!
Have been playing (not listening) for my Isabellina for 2 hours. I know that I need to burn it in for 100 hours. Please tell me if I should use pink noise, white noise or just play the sound tracks to burn it in? Also, do I need to burn in each of the inputs as well? Thanks. |
I highly recommend that you just play music for burn-in, and listen to it and
enjoy it throughout the burn-in process.
You don't need to burn-in the three inputs separately - they all feed the same NOS dac chip, analog output stage, volume control, headphone output stage, etc.
I do recommend that you leave headphones plugged and music playing during the burn-in process. The headphones provide the "load" to the headphone stage that allows electrical current to flow.
ONE MORE THING TO NOTE - Regarding SMART Board
Miguel had his Isabellina HPA burning-in for many hours (I think around 20 hours continuously) and he mentioned to me that the red power button light on the front panel then began to start to flash. This is NORMAL - it is the SMART module telling you that the battery voltage is getting close to the "trip point" where the SMART board is going to shut the unit down and begin charging (in order to prevent the battery from being deep cycled).
Also - for every 3 hours of use, it takes approx. 1 hour to charge. This is just an estimate, not an exact figure. Ideally, don't always run the battery down to the point where the SMART board shuts the unit down. I know you want to put on the burn-in time, but it is always best for the battery to just shut off the unit (allowing it to charge) as soon as you are finished listening. This will give you the most battery longevity...
All the best,
Vinnie
PS: Nice pics, Miguel! Thanks for posting those shots!
