- Oct 19, 2008
I've listened to the XTC Closed for about a month or so and am blown away. So I wanted to compare them to other high end headphones. So I bought the ZMF verite opens and atrium open that came in yesterday. They don't even hold the XTCs nut sack. Don't get me wrong, they are beyond beautiful and have incredible build. The ZMFs sound muffled and have too much dampening going on. The XTC has more clarity, imaging, tight bass, and separation. The XTC is all around better except for build quality. I feel like I blew almost $6,000 on headphones that won't even be my everyday listeners. Kind of a bummer. John has something special going on.
Hey guys - really appreciate you trying our headphones.I got a similar impression from ZMF with regard to being muffled. It was like you had a pillow or blanket over your head was the best way I could describe it.
This isn't true for all ZMF though. The Caldera I found didn't suffer from this and was terrific sounding to me. Definitely ZMFs finest headphone. Then actually their lower tier headphones like the Eikon I thought also were less muffled and a little better. The Verite gets so much praise that I thought the Verite Closed would be my next headphone - very glad I was able to try it before buying.
That said, it's really about personal preferences. There's definitely a lot of folks who like what ZMF has going on and that's perfectly fine.
The challenge is in trying to describe what you hear and trying to read impressions from everyone else out there who have different tastes and ears.
For the time being, it's certainly easier to try a ZMF somewhere at a meetup or CanJam than it would be finding an XTC to try. I bring the XTC with me to meets though. I definitely would suggest to everyone who asks to try any headphone over $500 before buying.
One thing that has to be considered is that the dynamic ZMFs use 300 ohm drivers, the XTC and many other easy to drive dynamics are optimized for sources with super low impedance and their ceiling comes much sooner because of the lighter more excitable voice coil.
ZMFs (and many other high impedance headphones) with those same low impedance sources will sound muffled, as the voice coil is heavier and longer to get the high impedance. So if you plug the zmf into the same amp as a low impedance dynamic ofcourse the zmf will sound more damped, it literally is. This is also probably a big reason you liked the Caldera more of you listened to it on a similar amp, as the impedance and system is much lower and easier to driver with current vs higher voltage/impedance.
People think ZMFs sound best or are optimized for tubes because of this, which they aren't, they just need a lot of power without a super low damping factor for the 300 ohm output. They will change the tuning greatly and you also can alter the tuning slightly with different front meshes and pads.
I think what JM is going is awesome! I don't think derogatory comparisons are needed, as clearly the drivers and systems are very different for different audiences, and that's what's fun about audio!
We are creating easier drive headphones with lower impedance custom drivers as well as lesser priced planars that will have trickle down technology as well, which will be more similar to other lower impedance stuff out there.
Thanks guys.
ZMF headphones hand-crafts wood headphones in Chicago, USA with special attention to exceptional sound and craftsmanship.
Stay updated on ZMFheadphones at their sponsor profile on Head-Fi.
