- Feb 1, 2011
Don't suppose many of you have seen this, looks like a fantastic piece of kit and well worth the money. Shall see once mine arrives.
http://keces-audio-usa.com/products/S-3
Introducing the S-3 DAC Headphone Amplifier & Preamplifier utilizing the high-performance ESS ES9026PRO along with a powerful balanced headphone output and a remote control for a complete audiophile desktop solution.
Features
1. High Quality Toroidal Power Transformer.
2. High-performance DAC-ESS ES9026PRO.
3. USB DAC: PCM 32 bit/384kHz and DSD DSD64(DoP)/DSD128 (DoP) DSD64/DSD128/DSD256 (ASIO Native).
4. COAXIAL/OPTICAL DAC: PCM 24 bit/192kHz and DSD DSD64(DoP).
5. Placed Balanced/Unbalanced Headphone output: Max Output Power 2000mW + 2000mW@32ohms.
6. Placed RCA/XLR Input/Output interface: Could be a Preamplifier.
7. Volume Control System: 128 step attenuator. Accurate control volume to achieve left/right channel balanced.
8. Isolation circuit: Completely separates the grounding of the digital and analog sections.
9. Volume/Source/Sampling display using OLED has excellent visibility.
10. The 4mm thickness of the aluminum chassis to effective to blocks EMI/RFI interference.
11. The full-metal body realizes both vibration control and elegant style in an A4-size body that enables placement on a desktop to be a PC HIFI system or to be a small stereo system.
Specifications
Digital Input:
COAXIAL: PCM support up to 16-24Bit /44.1kHz、48kHz、88.2kHz、96kHz、176.4kHz
192kHz. DSD support up to DSD64 (DoP).
OPTICAL: PCM support up to 16-24Bit/44.1kHz、48kHz、88.2kHz、96kHz、176.4kHz、
USB: PCM support up to 16-32Bit/44.1kHz 、 48kHz 、 88.2kHz 、 96kHz 、 176.4kHz 、 192kHz、352.8kHz、384kHz. DSD support up to DSD64(DoP)/DSD128 (DoP) DSD64/DSD128/DSD256 (ASIO Native)
Analog Input:
XLR: Input Impedance: 47k Ω.
Max Input Level: 10Vrms.
Input/Output Gain: 0dB
RCA: Input Impedance: 47k Ω.
Max Input Level: 5Vrms.
Analog Output:
XLR: SNR: >-122dB 20Hz-20kHz A-Weighting.
THD+N: <0.0004% at 1kHz A-Weighting.
Frequency Response: 20Hz-20kHz(+0dB/-0.09dB).
Channel Crosstalk: >-124dB@1kHz.
XLR output: 0-4Vrms Adjustable at 0dBFS.
RCA: SNR: >-119dB 20Hz-20kHz A-Weighting.
THD+N: <0.0007% at 1kHz A-Weighting.
Frequency Response: 20Hz-20kHz (+0dB/-0.03dB).
Channel Crosstalk: >-122dB@1kHz.
RCA output: 0-2Vrms Adjustable at 0dBFS.
Headphone Output:
XLR_4PIN: SNR: >-120db 20Hz-20kHz A-Weighting.
THD+N: <0.00115% at 1kHz A-Weighting at 300ohms 100mW.
Frequency Response: 20Hz-20kHz (+0dB/-0.09dB).
Output Impedance: 0.6ohms.
2000mW at 32ohms at THD+N=0.1%.
1200mW at 300ohms at THD+N=0.1%.
650mW at 600ohms at THD+N=0.1%.
6.35mm: SNR: >-108db 20Hz-20kHz A-Weighting.
THD+N: <0.0015% at 1kHz A-Weighting at 300ohms 100mW.
1200mW at 32ohms at THD+N=0.1%.
350mW at 300ohms at THD+N=0.1%.
175mW at 600ohms at THD+N=0.1%.
Features
Specifications
Digital Input:
Analog Input:
Analog Output:
Headphone Output:
