Unfortunately, most people already own the PP. No need to buy it again just to balance it.It seems to me that those cables would work for the Porta Pro Utility as well...
Koss KPH40 Utility Review/Impressions
- Thread starter Mad Lust Envy
Unless there are balanced outputs I want to run a Porta Pro on.Unfortunately, most people already own the PP. No need to buy it again just to balance it.
SolaVirtus
Thanks for the tip on these. I wouldn't have thought to look for these on Hart's site. I like the cable! It's thicker/heavier than the stock one, but doesn't cause me any problem. It definitely makes KPH40 more accessible on my desktop setups. And portable, it's nice to be able to run it balanced and get more juice on a KA3 dongle or ifi Go Blu.Hart Audio sells balanced KPH40 cables.
alonzomoselyfbi
Has anyone found a good case when traveling with kph40? Around the neck isn’t always practical for me, and these look like they’d need protection in a bag.
Knee Deep In Epoxy
I just use a geekria pu-leather drawstring pouchHas anyone found a good case when traveling with kph40? Around the neck isn’t always practical for me, and these look like they’d need protection in a bag.
alonzomoselyfbi
I always wonder how drawstring pouches provide enough protection. kph40, especially the glued plastic housing, seems brittle. Maybe I’ve got the wrong idea.I just use a geekria pu-leather drawstring pouch
Knee Deep In Epoxy
It's not the best for protecting if plan to store them somewhere where they can get crushed.I always wonder how drawstring pouches provide enough protection. kph40, especially the glued plastic housing, seems brittle. Maybe I’ve got the wrong idea.
Geekria do have loads of hard cases so you might find an option.
Louis8ball
- Apr 26, 2009
How much sound leakage with these? Is it on the same level as Grado’s base model item?
Knee Deep In Epoxy
No where near as much as a grado.
But don't expect closed back isolation levels
Louis8ball
- Apr 26, 2009
Thanks
Louis8ball
- Apr 26, 2009
So is this item essentially the same thing as the PortaPro, but just in a different package?
They sound a little different. The same driver but has a differently designed rear enclosure, some people think that affects the sound slightly. And the lighter clamping force makes them sound slightly different too. Basically they have a little less sub bass than the Portas but that makes everything else sound a little clearerSo is this item essentially the same thing as the PortaPro, but just in a different package?
Louis8ball
- Apr 26, 2009
Ok, thanks for your responseThey sound a little different. The same driver but has a differently designed rear enclosure, some people think that affects the sound slightly. And the lighter clamping force makes them sound slightly different too. Basically they have a little less sub bass than the Portas but that makes everything else sound a little clearer
Quadrangulator
I just took delivery of a new set of KPH40's, love their sound (as I suspected I would since I've enjoyed KSC75's for years), but have a question about the cable.
Is anyone else's twisted from the earcup to the 2.5mm connector? My left cable twists ~3 times while the right cable does not, which forces both cables to twist and the 2.5mm connector to sit higher up. Yeah, I know, this thing is 40 bucks. But still. Is this par for the course?
Either way, does anyone do MMCX mods for pay?
Stevehamny
Sorry to hear about your cable anomaly! That would drive me crazy, much as I would otherwise still love the sound of my new KPH40s.I just took delivery of a new set of KPH40's, love their sound (as I suspected I would since I've enjoyed KSC75's for years), but have a question about the cable.
I just did an MMCX mod on the KSC75 (very easy if you have the replacement connector pieces 3D-printed for you):
(Sorry, the shot's kinda dark.)
But if I were going to mod the KPH40, I would grab these from Amazon:
Voarmaks DIY Modification MMCX Sockets Cover Parts
These were originally designed for the Portapro, but I believe the opening on the back of the KPH40 is the same size, so these should work just as well.
The soldering on this is easy, by the way. De-solder the old wires, replace with the new (red wire goes to the side with the red dot). The new wires come pre-tinned and there's already a generous amount of solder on the leads so it's pretty foolproof. A couple quick touches with the iron and you're done. (Also, there's a helpful video on the Amazon page cited above.)
(I'm far from an expert, so please anyone here with more skills/experience, feel free to correct me if I'm off-base on anything. Just wanted to offer some help as I literally just did the KSC75s yesterday.)
