Always a good day when new transformers arrive. Got my 1:14 MC SUTs along with my new HY69 amplifier output transformers. The outputs are 7K primary and I simplified things a bit with just two secondary taps, 100ohms and 32ohms. I'll have to polish up the brass end bells like I did on the other set. The old transformers are going to burn a hole in my pocket, need to do something with them.
I am rebuilding the HY69 amp yet again. It's the forever amp so it has to be perfect and I decided I need ideal output transformers and it needs to be fixed bias, so it's going to be a three chassis amplifier. One chassis for the AVC, which is already done, one chassis for the power supply, and one chassis for the signal. I'll also be ditching the cathode bypass and going fixed bias with Simpson meters.
Gonna take some time as I need to work on layouts, chassis, and circuit changes to go fixed bias. Hopefully will have the rebuild done and my LCR phono done by the end of the summer.
