That worked. ThanksAARGH! Same problem here with iOS 16. I found the fix, though, searching the web via Google. The answer is that the upgrade (this has happened before with other iOS upgrades) turned "off" a previous setting that you and I had "on" (idiots at Apple). In Settings, go to "Face ID & Passcode." After entering your passcode, scroll down to the bottom of the settings listed there. The second to last entry is "USB Accessories." You and I had it turned ON before, but the iOS 16 upgrade turned it off, so slide the button to turn it back on. The displayed information says "Turn off to prevent USB accessories from connecting when your iPhone has been locked for more than an hour."
Lotoo PAW S2 USB DAC AMP 150 mW@32 ohm 4.4 , MQA - New Firmware released 26 January 2.0.0.5 link added first post.
- Thread starter musicday
- Tags
- lotoo lotoo paw lotoo paw s2
NJoyzAudio
JMLAARGH! Same problem here with iOS 16. I found the fix, though, searching the web via Google. The answer is that the upgrade (this has happened before with other iOS upgrades) turned "off" a previous setting that you and I had "on" (idiots at Apple). In Settings, go to "Face ID & Passcode." After entering your passcode, scroll down to the bottom of the settings listed there. The second to last entry is "USB Accessories." You and I had it turned ON before, but the iOS 16 upgrade turned it off, so slide the button to turn it back on. The displayed information says "Turn off to prevent USB accessories from connecting when your iPhone has been locked for more than an hour."
THANK YOU FOR POSTING THE FIX!
sg2k
- Dec 18, 2012
Hi, is this Dongle capable for Bitperfect Playback on Windows?
Thanks
Thanks
bencherian
Hi just wanted to ask a question. Can it drive Hifiman Edition XS easily?
I have ordered a Lotoo Paw S2 Lighting Version. Today i have received that. But I cannot understatnd whether it is the lighting version or the type C version. Because there aren't any differentiate mark on the box. Should I open it or send back to China? .. I am totally confused
- Oct 6, 2013
There is only one S2, comes standard with two usb-c cables, short and long one. Whoever sold it to you probably bundled it with usb-c to lightning otg cable. Double check that it is included.
Sulbh
- Jan 12, 2014
Hi do you know if there is a significant difference between S1 and S2 in terms of power output? Numbers don't really show much difference specifically in balanced.There is only one S2, comes standard with two usb-c cables, short and long one. Whoever sold it to you probably bundled it with usb-c to lightning otg cable. Double check that it is included.
- Oct 6, 2013
No significant difference, just recall there was a boost in 3.5mm between S2 and S1. The noticeable difference was in sound quality. I covered it here.
Sulbh
- Jan 12, 2014
So S2 or Questyle M15 just for sound quality?No significant difference, just recall there was a boost in 3.5mm between S2 and S1. The noticeable difference was in sound quality. I covered it here.
dennis611
- Jul 30, 2013
I purchased the UAPP in app MQA. While Mqa decoding works well with my LG V30 and S2 shows mqa 4x, it doesnt work with my Note 10 Lite. I thought it will work on all android phones. Anyone having the same issue?
I've got both... Those devices are great but really different in flavor. It depends Yours taste, IEM pairing rather SQ. In short... smoother presentation with multi-layered low-end -> S2, more air with great dynamics with raw "power" and so'called Sabre sparke -> M15.So S2 or Questyle M15 just for sound quality?
maceto
- Jul 4, 2009
The S2 is great; it provides some nice color and settings my Mojo2 doesn't, especially in Tidal. For Apple music, I am still experimenting with the settings.
sg2k
- Dec 18, 2012
Can somebody say something about the Output Impedance (SE/Balanced)? How low is it? I can't find anything about it in the WWW.
aohk1997
- May 7, 2013
Just got mine a week ago and facing some issues, my local distributor is contacting lotoo for an answer too as they don’t have a way to help me but thought I’ll try my luck here
There is some popping and crackling noise when I use the lotoo paw s2 (latest firmware) with my iPhone 13 Pro iOS 16.1.1. The issue is specifically for this device pairing as I have tried other devices with no issues as well as switched the cables
Anyone has any idea what’s going on?
lmfboy01
- Apr 26, 2007
It should come in a different box, at least my lightning cable mine did.I have ordered a Lotoo Paw S2 Lighting Version. Today i have received that. But I cannot understatnd whether it is the lighting version or the type C version. Because there aren't any differentiate mark on the box. Should I open it or send back to China? .. I am totally confused
