thecrow
- Oct 18, 2014
I have been having a white noise issue coming out of my setup and i’m hoping someone might help
I have my imac running the latest software (sierra 10.12.6) connected to my metrum hex connect via usb.
i am spasmodically getting very loud white noise/static coming through. I can’t hear any music as this statics very loud.
The music is still showing as playing. If i pause the music and restart the noise goes away but quite often comes back again shortly.
I sometimes close the app/music player and sometimes restart the computer. This sometimes stops the problem however i don’t think it is completely connected to (or solved by) that as i can do that a number of times and there is no change but after a number of times (or me giving up) the static may stop coming up and not occur for an hour, or a few days or even a week or two and then it occurs again
I have tried various music app /players in case that was the problem but again that does not change anything and this has occurred in a number of options i’ve used.
These include:
Tidal app;
Tidal via google chrome;
Audirvana 2+ - streaming tidal and playing music from my connected external hard drive (iTunes library);
my secondary iTunes library on my internal hard drive.
This also occurs when listening to music on my connected amp (woo audio wa2 connected via RCA) and also when listening through my jbl monitors (via balanced connections)
as i’ve tried various options here i’m assuming i have an issue with an internal part of my hex dac or at least the connection it has with my imac
I also just recently updated my usb to a premium usb cabe (audience au24 se) but again that has had no change
what can i do and/or what is it likely to be?
thanks in advance
These include:
Tidal app;
thanks in advance
