I am intrigued! Can you say what your top reasons for choosing over the W4 were? I wasn’t feeling the need to upgrade, but you know how it goes… don’t want to be missing out on something better!Yup! However, W4 now sold as of today.
Luxury & Precision (LP) W4, Successor to Their Popular W1/W2 USB Dongle is Here!
- Thread starter bluestorm1992
Biggest differences for me are in the staging and imagining departments- I was using my UM MM Mentor for the comparison.I am intrigued! Can you say what your top reasons for choosing over the W4 were? I wasn’t feeling the need to upgrade, but you know how it goes… don’t want to be missing out on something better!
I also have quite a bit of beef with L&P not providing an update for older products (like my W2-131), which no longer work with the new usb-c iPhones. The only solution was to get my unit over to China to have its software updated with me covering shipping both ways...
Well, that is an excellent reason to have beef. Kind of shocking that that was the only way to fix it!The only solution was to get my unit over to China to have its software updated with me covering shipping both ways...
makbrown
I see from your signature that you own/owned DC Elite and Mojo 2. Can you compare them with each other and of course with W4, since this is a W4 topic.Biggest differences for me are in the staging and imagining departments- I was using my UM MM Mentor for the comparison.
could anyone tell me how the IE600 filter sounds please ? I have a shanling M1s at the moment sold my DX320 so wondering if it would be worth getting the M4-M4 EX to replace the M1s
I have error 204 displaying on first connection any ideas
Maybe you need to reinstall the firmware. Are you using the latest? : V1.0.1.6 ASI have error 204 displaying on first connection any ideas
I’m unable to install anythingMaybe you need to reinstall the firmware. Are you using the latest? : V1.0.1.6 AS
The W4 won’t connect to computer if I look In devices on my PC I get this message
unknown usb device
Driver issuesI can get it from error 204 by holding the button down when inserting into usb slot to 101 102 etc but still nothing the instructions are very poor
If I unplug and reinsert goes back to 204
Are you using a windows pc? Try to follow the information found on the first page, how to recover and install the update.
I do have a pc
I have tried the recover and update just can’t get anything to work
I’m more of a Mac user so not too good with a pc
CactusPete23
I don't have a W4, but on the device itself you are supposed to be able to check your firmware version.I’m unable to install anything
unknown usb device
Driver issues
Quoting "Check the current firmware version number: After entering the UAC version menu, long press to display the current firmware version number."
Unsure if it needs Windows drivers. Might want to download the latest firmware update zip file. And run the install tool. MAybe the W4 will be detected?
Also consider trying a different USB Port on your PC, sometimes 1 will work better than another. And sometimes woks better on slower usb port if you have...
Link to download the frimware zip file: https://drive.google.com/file/d/12FgZTej2XQZcQ-IBjz9rUnzI577F3ceq/view?usp=drive_linck From Musicteck...
CactusPete23
Maybe try a different cable, or a different USB port on yiur computer? Just a thought...I can’t get past this to check firmware etc
I’ll give it a go thanksMaybe try a different cable, or a different USB port on yiur computer? Just a thought...
CactusPete23
Unsure if needed, but there seem to be some windows drivers on the L&P website. These are mentioned on the firmware download page... https://pan.baidu.com/share/init?surl=PdiEh0yywrChHwXtiSKy1w&pwd=z347I can’t get past this to check firmware etc
L&P Firmware download page = http://www.luxuryprecision.net/xiazai/
In Google Chrome, I Right clicked TRANSLATE, to read the Chinese....
Total: 11 (members: 1, guests: 10)
