TyTB
- Jun 17, 2012
Hello people,
I've noticed, in my pursuit of better audio gear, that a lot of stuff doesn't seem to be designed with constant on-off cycles in mind.
Like, for example, a Lyr+ amp from Schiit has its power switch on the back. And it takes 30 seconds or so to actually turn on, once it's turned on.
I'm trying to think of how this interfaces with a desktop computer environment. Right now, I listen to my headphones directly off a Grace SDAC.
The Grace SDAC stays powered 24/7, even when the computer is on standby. When the computer is on, it's able to output sound without delay.
I realize that with a tube amp, this won't be possible, as I'd burn through the tubes VERY quickly. But what about solid-state stuff? Even Schiit's Jotunheim 2 amp has its power switch on the back. It seems like high-end audio gear is intended for dedicated listening sessions, once a day or a few times a week, for example. Not on-and-off-and-on-and-off 10 times in a single day, every time your computer boots or goes to sleep.
Is this something I should actually take into consideration? Are there dacs and amps that are specifically meant for a computer-listening setup, or will I be fine using something like a Lyr+ and a Modius, just manually toggling the Lyr on and off every time I sit down/leave the computer? Keep in mind the modius will have to stay on 24/7, as it doesn't even HAVE a power switch.
How does buying used factor into all this? In my mind, amps and dacs should last 20+ years no problem, as they're all solid-state machines, minus the tubes, and the natural lifespan limits that exist on capacitors.
