Thank you @Baten, understood. Do you know what oversampling method Matris X-Sabre uses, PCM or DSD-based?Not possible. There are some rare Sabre DACs like this one https://allo.com/sparky/revolution-dac.html
that allow to disable the oversampling filter with OSF bypass setting. Matrix X-Sabre does not expose this. So no way to do that.
Matrix Audio X-Sabre Pro
- Thread starter mtoc
Baten
- Sep 13, 2012
Unfortunately, no. The datasheet of the ESS Sabre 9038Pro chip is not public and under NDA for those implementing it. So I think few people know exactly what is behind it.Thank you @Baten, understood. Do you know what oversampling method Matris X-Sabre uses, PCM or DSD-based?
IS this the data sheet you are talking about, or something different.
Baten
- Sep 13, 2012
Wow, where did you find this lol ;P it says it is confidential So it looks like it expects every rate to be 8x oversampled, in either a 128-tap or 256-tap filter. Not very in-depth details though... even the user-programmable filter is a very basic example.IS this the data sheet you are talking about, or something different.
Amazing what you can find on the net LOLWow, where did you find this lol ;P it says it is confidential So it looks like it expects every rate to be 8x oversampled, in either a 128-tap or 256-tap filter. Not very in-depth details though... even the user-programmable filter is a very basic example.
Sound Eq
- Nov 9, 2013
can i ask would the matrix element x have the same dac sonics as the x sabre pro when both used as just a dac, as the martix x is an all in one, but if i will connect both to my home system would they sound the same
thecrow
- Oct 18, 2014
I recently bought a used x sabre pro (non mqa)
Firmware verison 1.3
Should i be ugrading the firmware? If so, where?
I am using it with an imac
thanks
thanks
Thenewguy007
- Jun 22, 2013
thanks
https://www.matrix-digi.com/en/news/20200922495.html
Also make sure to upample through your audio player to at least 48 or 88 Hz for PCM, as the upsampling in the Matrix measures bad & is a bottleneck.
thecrow
- Oct 18, 2014
thanks for replying.https://www.matrix-digi.com/en/news/20200922495.html
unfortunately that’s just for mqa model with a warning not to use it with the non mqa dac
tejanolibre
thanks
YOU SHOULD DEFINITELY USE THE OFICIAL :
Matrix Audio USA WEBSITE to download anything that's available!
It called:
Matrix (power-holdings-inc.com)
And Mr. Powers is a Good Friend of "ours!"
Best of Luck and health to all !
I gave mine away unfortunately ! ONLY one in my ENTIRE COUNTRY but I was able to Get about $10K for it after 2 years of EXCELLENT USAGE and I definitely want another one!
But they have been Discontinued!
I just Love the Design but maybe , more than Likely the Latest TECHNOLOGY is the absolute BEST ON THE BLOCK!
All Things Considered!
Happy Listening!
Best of Health!
sincerely ,
Ramiro Guerrero
Giving AWAY N.O.S Tung-sol Matched USA manufactured "Legendary" Vacuum Tubes! Almost Giving AWAY!
thecrow
- Oct 18, 2014
Yes.YOU SHOULD DEFINITELY USE THE OFICIAL :
It called:
Happy Listening!
Best of Health!
sincerely ,
Ramiro Guerrero
i’ve emailed Arthur in the past and he has been very useful
i emailed matrix audio yesterday and hopefully i’ll hear from them after chinese new year in the next week or so
thanks
Stereolab42
- May 11, 2014
Unboxing therapy:
- Moon Audio has these in stock and can get it to you overnight.
- They're not kidding about this thing being carved out a single block of whateverium, it weights a TON for its size. Do NOT try to lift this with one hand unless you want to take out your floor along with the DAC.
- Everything about the build quality is unreal. People are scared to pay this much for audio equipment out of China because of the quality of the $200 stuff. But this is $2300 and it could not be more different. if I paid $10k for an MSB DAC I'd be glad if it looked and felt like this.
- I'm not a fan of the three feet, I'd rather not have the corner of the unit hitting the table when the cat walks on it or you lean down on it for a moment when wiring stuff. (Who started this idiotic trend in hi-fi? Schiit's newer stuff has three feet also, so it's not something unique to Matrix.)
- Voltage switch was set to 220v out-of-the-box. Boy I'm glad I checked first. I hope it has built-in protection against wrongly selected voltage because I'm sure a significant percentage of customers just plug stuff in and pray.
- Nice selection of options in the setup. I think I have jitter protection off, dither off, and PCM filter 3, which is what some random guy who seemed kinda wise suggested on a forum post somewhere.
- Zero trouble getting the device recognized by Windows and playing a variety of sound files. Works fine without the driver, but with the driver you get ASIO and theoretically bit-perfect sound if you haven't screwed something else up.
- I have a Matrix Audio element H USB card coming also. Not sure it will make a difference but for $300 why not get a dedicated, low-noise USB jack for my DAC.
- Yes, it sounds great. But I'm not going to pretend it sounds noticeably different from other competently-made DACs. I realize I'm paying the majority of the $2300 for jewelry and overengineering (peace of mind). And I'm fine with that.
@Stereolab42
Congrats man. Enjoy!
If u can manage a singxer ddc, try out the i2s connection to the matrix. It is really really good! I also preferred sync over async when using with the singxer.
Congrats and enjoy! Good info about the default set to 220V - I have the Matrix mini-i Pro 3 and didn't realize the 220V default. Fortunately nothing bad happened other than it not working, unplugged it and checked everything and saw the voltage switch set to 220. A quick flip and I was rocking to tunes shortly thereafter.Unboxing therapy:
Thenewguy007
- Jun 22, 2013
Try to upsample with your music player if you are listening to PCM, apparently the X-Sabre measures poorly for that by itself, but upsample from a music player (jRiver, HQplayer etc) can be a big jump in quality.
