micro to mini usb otg cable
Apr 23, 2013 at 11:49 AM Post #16 of 40
thanks, this is just the thread i was hoping to find here to connect my htc one to my fiio e17 without using a series of bulky adapters.  it'd be even better if there were a version with right angle connectors, but this should work... (not too excited about the $7 international shipping to US though)
edit:  i also emailed http://stores.ebay.com/shelia-ewholesale?_trksid=p2047675.l2563  with the suggestion of offering a 3" cable with a right angle micro to mini usb otg cable...
I think this one was reported to work as well:
http://www.ebay.com/itm/310623227449?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
May 20, 2013 at 8:27 AM Post #19 of 40
OTG cable is one important accessories in smart phone but many manufacturer are not provide, so we find the simplest way to make OTG cable at our home. Some waste things like USB and MicroUSB used to making it. In market if we purchase we have to pay 5$ for that but here we can make it free of cost just using waste usb pins. following link guids you how to make easily OTG cable.
http://everysolutionshere.blogspot.in/2013/05/how-to-make-otgon-to-go-cable-for.htype=POST
May 26, 2014 at 2:23 PM Post #25 of 40
Thanks, I look forward to hearing how it does.
Unfortunately it may be too short for my needs.  I have to go from the side of a RAZR M to the bottom of a FiiO E17.
Yeah, that size isn't going to work very well for you if you're trying to stack the two. I'll be on the lookout for something longer.
Jun 1, 2014 at 7:15 PM Post #26 of 40
Hope no one minds me jumping on to this thread as my requirements are the same, I believe .
I have read numerous threads, including some with over one hundred replies to no avail.
I wish to connect usb output from my Samsung Note 3 (SM-N9005) running Android (4.4.2) to my Fiio E17 usb input.
My previous setup, used with HTC One M7 to Fiio E17 originally was labelled for or by ibasso worked well on above combination and Note 3 to Fiio E17.
I need a replacement cable, I believe it's OTG
(E17 is host ?) with usb micro male for Note 3 end and usb mini male for E17.
length ideally 12 to 15 cm, decent quality cable although don't wish to buy in to ultra expensive mono crystal silver / ofc.
Suggestions and purchase links gratefully received
Aug 1, 2015 at 7:44 AM Post #28 of 40
I know its been a while since this thread has been bumped however I found something which may help some people.
Mini to Micro USB OTG cable.
Right angle jacks.
10cm total lengh.
$5.99
The seller states it is OTG and wired the correct way for DAC use.
http://www.ebay.com/itm/301556014007?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Please keep in mind I have ordered though not yet tried it.
I will return and edit in if the cable works with my Galaxy S4, S3.
EDIT: 20 - August - 2015.
The cable arrived and is confirmed working with my Samsung Galaxy S4.
Aug 10, 2015 at 11:57 AM Post #29 of 40
Right angle jacks.
10cm total lengh.
$5.99
I just ordered from the same seller the micro USB>micro USB variant for my HRT dSp and Sony Xperia Z2. Thanks for the link, this kind of USB cable is very hard to find.
