I'm probably going to be upgrading my PC in the near future and was curious if anyone knows whether there are manufacturers to avoid or gravitate towards as far as the quality of their USB outputs go. I use a USB 2.0 output from the motherboard into the USB-C input on my Schii Modi Multibit 2. I'd be looking at the typical motherboard manufacturers like Asus, Gigabyte, MSI, and ASRock.
I realize that motherboard USB might not be the best possible quality, but I'm not ready to get into the world of streamers and all that yet. I appreciate any input about whether the manufacturer or motherboard model really matters much for USB noise/jitter!
I'm not feeling well, so I'm not going to stick around this thread after my post.
I hate using the motherboard USB, so the Manufacturer is not much of a concern for I. There's just too many pollutants in a motherboard's USB bus. Just think about all the times you insert a USB stick and get no response. Motherboard USB ports totally not quality, totally. With PCI-E USB cards, you have a dedicated path to the CPU for USB use cases.
So I recommend a Asmedia 3142 USB chipset from Startech:
https://www.startech.com/en-us/search?search_term=pcie usb
https://www.startech.com/en-us/cards-adapters/pexusb312c3
Just make sure the specs indicate Asmedia 3142 chipset.
Sometimes, provantage has good deals on Startech products. I always check before buying elsewhere:
https://www.provantage.com/service/searchsvcs/Q?SEC=&QUERY=startech+pci-e&SUBMIT.x=0&SUBMIT.y=0
If you look at JCAT USB Card XE, they also use Asmedia 3142:
https://jcat.eu/product/usb-card-xe/
If the Graphics card blocks a PCI-E lane (takes two slots), there are extension adapters on Amazon as a workaround.
I combine this with a USB optical cable and a Uptone USPCB because I hate traditional wiring.
https://www.whatsbestforum.com/threads/taiko-audio-sgm-extreme-the-crème-de-la-crème.27433/post-631947
I power the USB optical cable with Industrial Strength Super Capacitors 24/7 @5V @a few thousand Farads. This allows me to be completely off Mains. It needs 3 minutes at a random time to fully re-charge over a 24 hour period, then it goes back to being completely off Noisy Mains power 100% via optical isolators.
If I can't use USB optical, then I make my own solid core USB PWR cables. I have not tried making my own solid core USB DATA cables yet as I use USB optical for that use case. I believe EMI/RFI cannot sneak into solid core as it can with traditional cooper wiring because it's not penetrable. The above photo is using thick, cooper solid core @12 Guage. I use 20-22 Guage for USB PWR solid core cables.
I only use this for Gaming only though with an FPGA DAC as I'm running a low latency realtime kernel Audiophile OS. I have another dedicated Music Server powered by Super Capacitors for Music dedicated exclusively to only 16-bit original CD sample rate. With anything USB, you need to convert to 32-bit before hitting the DAC so I stay away completely from USB for Music enjoyment, USB for Gaming only is okay.
Good luck. Good question.
Going forward, I'm trying to only procure PC's which I can power with Super Capacitors (No Noisy Mains) and has at least one PCI-E lane because zero to low noise is addictive and good for ear health since I can listen at super low volumes with all the details:
