vermilions
- Mar 23, 2013
Is there anyone who has heard both the Sunrise Audio Ray and the C&C BH? Which one would be more bang for the buck? I'll be using my Beyerdynamic T51p and Shure SE215 with them. Thanks
Check out the UHA-6S MKII, I has a built in DAC. It sure can drive the alpha dogs fine and you can use the amp section separately from the DAC.
Hi Average_Joe,
I posted a question in the Help Forum but didn't get a answer. I'm hoping you can help.
First, I'm rather new to headphones and Amps/DACs. I plan on purchasing the Alpha Dog with the primary devices being phones, laptops/PCs. and tablets.
So, I am looking for a single AMP/DAC device that can drive the Alpha Dog. A DAC to use with my Windows 8 devices via USB and AMP to use with my Nokia phone using line out/in (I'm assuming I will benefit of having a portal AMP for the headphone).
I've been looking through your thread and others and the one that seems to fit the bill is HiFi M8. However, it's outside my budget and looks too big. My budget is <$300, preferable <$200.
Is there a single device that fits my need?
Thanks in advance for your help.
Yes, the UHA 6-S MK II is a good option. There is also the ADL Stride, which is the cheaper version of the Cruise. There is a hiss issue with sensitive IEMs, but worked well with headphones for me.
UHA:
- Rollable opamps
- Gain switch
- Use as an Android/Apple DAC
- Optical input needed for 24/96
- Size/shape is better
- Micro USB connector
Stride:
- Higher overall sound quality
- 24/96 via USB
- Over 2x battery life (80 hours per the manufacturer)
- Mini USB connector
- Does not support tablets
