Yes as expected. I was considering either the A6 ME or Pegasus, after many days of readings and watching reviews, I think an R2R dac would be suitable for meBecause I only use it as a streamer and prefer external R2R DACs. The streamer part is the same in the Master A6. I am not too fussed about either of the built in d/s DACs.
I know, it sounds a bit like wasting money on the built in EverSolo DAC, but the streamer bit is so good and clean sounding, it is worth the asking price alone.
Musician Audio Pegasus R2R DAC
ColSaulTigh
100% agree on the fuse swap thing - makes the Pegasus punch so far above its weight class that it's not even funny.The Zen DAC is a great little entry level DAC. Pegasus is a different category, so yes, you should be able to hear the improvement. You could expect a bigger soundstage, better imaging, more life-like timbre and so on. With an upgrade fuse you can also further improve clarity, but even in stock form the Pegasus should be quite a jump from the Zen.
Tubewin
The Musician Taurus R2R dac was just released,
and already a review from Sandu:
MaxA
Agree, was in sceptic mode what to replacement, but decided to try, not the great price for such experiment and interesting. Especially attract the friend who if far from audio entertainments but like music for fuse replacement. BTW, he has the degree in radioelectronics. I was wondered, he was shocked, that cannot work in his mind, but the difference was really evident.100% agree on the fuse swap thing - makes the Pegasus punch so far above its weight class that it's not even funny.
BTW, doesn't remember in what direction we plugged it in. Does somebody try to reverse it? I ask about personal experience, not the legends
MaxA
Ok. I tested the SR Purple fuse direction and is that working at all. Yes, really, the difference is clear at once, no any long tests, just reverse, turn on, clear. Nothing to test. Difference - more clear and bright sound. I was listening this sound more than year so no any doubts.
Just when I was about to put an order on the Pegasus, I’ve learned that Holo audio Cyan2 has released and stock will be arriving soon and they have demo unit to test. Too bad our local dealer for Pegasus doesn’t have demo. This is tough decision to make
Johnybuchar
Hi folks,
I got Chinese fuse for testing but I don't know how to open top lid of Musician. Can I ask someone to advise it, please? I cannot see screw related to the lid.
Thank you!
Thank you!
Johnybuchar
Hi folks,
Thank you!
ColSaulTigh
Once you remove those screws, you have to pull the top UP and it's a bit snug. I had to tap mine loose with the soft end of a screwdriver. YMMV.
phoneslave86
I2s recently stopped working on my Pegasus. I was enjoying rolling I2s cables and had swapped them many times before this happened, so the HDMI port doesn't just simply break very easily. The fat I2s connectors obviously put too much pressure on the nearby Coax port. HDMI are known to internally break from pressure and not be the most robust of connections.
Does anyone know of someone who repairs Denafrips?
sajunky
If connector is broken, then good workshop can fix it. It doesn't need to be Denafrips service. Unless you afraid it will void warranty.I2s recently stopped working on my Pegasus. I was enjoying rolling I2s cables and had swapped them many times before this happened, so the HDMI port doesn't just simply break very easily. The fat I2s connectors obviously put too much pressure on the nearby Coax port. HDMI are known to internally break from pressure and not be the most robust of connections.
However HDMI ports are frequently damaged by static electricity. If you are hot-swaping, then it could be a case.
phoneslave86
Do need to find a matching I2s port though unless a regular HDMI port will work. It's not so easy to locate parts from Musician.If connector is broken, then good workshop can fix it. It doesn't need to be Denafrips service. Unless you afraid it will void warranty.
sajunky
It is regular HDMI connector. You can find the same type on Mouser, Digikey, etc. But don't try to replace yourself unless you have hot air rework station and elementary practice.Do need to find a matching I2s port though unless a regular HDMI port will work. It's not so easy to locate parts from Musician.
MaxA
Yes, that's very important in the case in microsolderingBut don't try to replace yourself unless you have hot air rework station and elementary practice.
phoneslave86
Thanks for the answers, very helpful. I've been struggling to get this fixed for sure. Thats big if I only need an HDMI port. Tempting to solder it myself as I can solder but I don't want to risk doing a sub par job. I will let a professional handle it for sure! Thankfully l have a well tuned AES cable to use.It is regular HDMI connector. You can find the same type on Mouser, Digikey, etc. But don't try to replace yourself unless you have hot air rework station and elementary practice.
