My Choral housed Chord Mscaler
Nov 6, 2023 at 2:16 PM Post #151 of 170
The part where I have highlighted, I’ve wondered about that for years, does the mscaler give us full 768 on left and right channels or was it 384 on each to make a total of 768 combined. Cheers for breaking my heart on my birthday :smiley::sweat_smile:
Good work though.
Easy test.. put scaler on 1M and connect one coax. Youll get mono sound in 352.8/384k of one channel of a stereo source.
The single SPDIF BNC (next to the dual bnc's) gives 352.8/384K in stereo
Nov 6, 2023 at 5:58 PM Post #152 of 170
Now you’ve said it, I could of done that earlier, but I didn’t bother as it wasn’t something that was high on my agenda. I was just curious as I do recall asking about it years ago, but I can’t remember if I found the answer, I suppose 384khz is ample for anyone at this period in time.
Cheers
Mar 17, 2024 at 6:32 PM Post #153 of 170
Hi. Reading this thread about the optical link some weeks ago, I decided to give it a try and started to order all the necessary things to make it . This is my first project in many years , because even if I'm an electronic engineer , I was too busy with my former job so , now that I'm retired I have a lot of time to dedicate to my hobby, my music system.
I made some changes to the original Reatcore idea:
-I decided to use aluminum cases to have a better shielding
-I decided to not take the power from the MScaler and TT2 power supplies , but to make them run on battery
The reasons are relatively simple: I spent a lot of money on 3 LPS from Sean Jacobs , an original DC3 I purchased second hand from the same person who sold me the MScaler , and 2 others I personally made using SJ original boards and purchasing all the other parts to make them aesthetically and technically almost identical to the original DC3.
I took that decision as I was totally disappointed by the sound of the original SMPS provided with the devices from Chord.
I found also that even replacing the umbilical cable between LPS and MScaler was impacting the sound quality.
For these reasons I decided to use 2 Lithium 9V rechargeable batteries .
They are rated 9V 650mAh: in reality they give around 8.7 V when they are fully charged , then the voltage decreases as the charge is depleting .
For this reason I slightly changed the power voltage regulation circuit replacing the trimmer with a 5.6V Zener diode polarized with a 50 Ohm resistor: this keeps the 5V relatively stable for a long time.
The transmitting box absorbs around 120mA giving the battery around 5 hours of running time before charge is gone.
The receiving box absorbs around 80mA (less components to run).
Just a note about this solution: when the battery level reaches the lowest level the link becomes unstable so the TT2 starts making very bad cracking noises. I think I will work on a different solution that gives more hours running, or I will try with a separate LPS (I'm not sure if this can give problems).
The batteries have an internal charging circuit , they can be charged using a standard phone charger , so I bought a cheap one with a double output , one for each box, and 2 long cables with USB A termination on one side and a micro USB termination on the other side, to keep it far from the system.
The power goes to a double diverter switch that in ON position powers only a blue power led and a small relay that closes the contacts between the battery output and the board.
When it's set in OFF position, it sends power only to the battery charging circuit ; it can be kept in this way for days without issues as the charge is automatically interrupted by the circuit inside the batteries.
In this way the battery charger is totally isolated from the digital circuit.
The aluminum box required some manual milling work to keep the BNC connectors as close as possible to the right lateral side.
This is needed to avoid interferences between the box and the cables connected to the TT2 and the MScaler.
I used a small Dremel-like mill to make that.
To fit the micro USB female connection on the back plate I had to manually mill the hole: the result is not nice at all, but it's on the back side so nobody can see it :slight_smile:
The front plate required just to drill the holes to fit the BNC connectors : their position is not exactly in the center of the plate but is the same for both the boxes even if the TT2 and the MScaler have different height : I used 2 different size sets of rubber feet to have the proper height for each box, in this way the 2 boxes are staying stably on the back of the devices without forcing on the BNC connectors.
I used the same board also for the receiver to have a mechanical support for the components, obviously I had to cut some tracks and use some jumpers to make it working.
A note about trimmers adjustment : I found that the most critical adjustment to have a stable connection was when I used DSD 64 (I don't have DSD at higher resolution, these files are from ripped SADCs), so I first followed the procedure from Reatcore (I was SO HAPPY when the link appeared on TT2 display) and then I observed , as he said , that increasing the resolution it becomes more and more difficult to have a stable connection. It's happened that the A fiber connection was the most critical, so I worked first on that and then set the B fiber trimmers on the same position. Follow his recommendations to avoid to damage the optical transceivers, they are the most expensive part. If you can reach a stable connection with DSD64, then all the other lower resolutions will work flawlessly.
And now some comments on the most important thing: how they sound?
For sure MUCH MUCH MUCH better than the original cables provided by Chord: much more informations , more clarity and details, they definitely worth the investment in money and time and it was a lot of fun, but also a challenge, making them.
I never had the possibility to test for comparison the Wave cables (the MScaler/DC3 previous owner was using the Storm between it and his Qutest, but I never heard them and I think he decided to sell everything because he wasn't totally happy with his system sound).
I decided for this way essentially for the cost , because I thought it is a very clever and non conventional idea and because I liked to challenge me on this project.
It allowed me also to understand that EMI can be a great problem.
Installing the optical link, I probably removed a big source of EMI and very likely the data transmission is also better as probably is not affected by cables capacitance, but I wasn't totally satisfied as some harshness and "digital artificial sound" was still present .
Reatcore pointed my attention toward EMI effects.
Now I would like to share my experience as I believe the optical link had a very important role on the benefits the sound had.
A couple of weeks ago I bought a 1.5 mt power cable from Puritan Audio, the Classic Plus. They are claiming an EMI absorption effect of their Classic Plus and Ultimate cables, so I decided to give it a try, it doesn't cost a fortune.
I tried it first on my preamp, then to the other devices and realized it was giving the best effect when it was used to power the MScaler LPS: slight less harshness and more calm sound.
All the other power cables I use are very cheap shielded stuff with a good section of apparently good copper.
PLEASE don't laugh , I know many people believe these are bul...its: this is my first experiment with "hi-fi power cables" and I didn't try with an expensive one, but my system allowed me to clearly hear the difference.
The effect may depend from system quality, but also from the problems that may affect it's performances, and this is valid for each component including all the cables (that's my personal opinion).
Reatcore suggested me to move the plug to a different power line: again BIG improvement, this is proof that EMI were coming from the MScaler through the LPS and affecting the other components ).
Observing how the "hi-fi power filters" are made, they normally contains DC filters and common/differential mode noise filters.
I've also seen that in some hi-fi components that uses linear PSUs similar to the ones I use , the power sockets are filtered against common/differential noise. So I searched on the web for informations about these devices that are available in several types and shapes : I decided to give a try to a 6A 250V double stage filter (33 euro+VAT and shipment) that claims a very high reduction of both common and differential mode noise, not only from the power line but also from the load side to prevent it pollutes the power line.
I can say that this filter made the miracle: a HUGE improvement!!
Now I can clearly hear that the sound , which is still slightly "metallic" after powering up the digital chain, opens up in some minutes revealing details I never heard before: it is natural and detailed, with a great soundstage, something I never heard before.
Now it's really nice to crank-up-the-volume knob to enjoy the musicians playing in my room.
This is in my opinion a confirmation that the optical link makes a great job.
Thanks Reatcore for your idea and your hints!!
I will post some pictures soon!
Mar 18, 2024 at 11:48 AM Post #154 of 170
What filter did you use?
Mar 18, 2024 at 2:14 PM Post #155 of 170
Thankyou for posting your project here! It was a fun read. Awaiting the pictures 😃
I noticed everytime a side of the DAC gets isolated one gets a few % improvement in depth and well just reality is the word i use.
Until you reach total floating electrical isolation of the DAC.. only possible with optical for Mscaled.. then it gets a leap forward easily hearable.
Then one truly hears what Mscaler can do.
Mar 18, 2024 at 5:36 PM Post #156 of 170
@mpino61 it looks as if you have been having fun. Having myself been on a journey through various power supplies with the Mscaler and Dave which started for me with a 3 rail DC3 supply for the Dave and a single rail DC3 supply for the Mscaler (and now is an ARC6 supply for each) I have been wondering why one would do all the optical isolation between these two devices and yet still use the original factory smps for the Dave.
I like your idea of using the battery supply and yet the motive for those who helped Sean Jacobs develop the ARC6 was to achieve a supply which exceeded the sound available from a battery (or in their case a whole array of batteries). The SJ ARC6 LPS is pretty far removed from the performance of the DC3 with the Dave and with the Mscaler.
The other thing which I think about is that my experience of incorporating fibre connection in local networks is that overall the amount of noise in the system seems to be more with the fibre in the system than is there in a well implemented copper system without the fibre and do you think this has any relevance when assessing using optical to connect the Mscaler to Dave? I guess the possible issue is how noisy the conversion circuit is to convert the optical signal back to an electrical signal.
Mar 19, 2024 at 2:24 AM Post #158 of 170
My journey with Chord devices started with the TT2 , the MScaler arrived later . I felt almost immediately that there was something that was not working as expected from a DAC of that level and reading some articles I arrived soon to the conclusion that a good lps was necessary , so I found a nearby DC3 on sale and the owner was so gentle to let me try it at home and that confirmed immediately the importance of a good power supply for these devices . And then he borrowed me his MScaler that was also selling , it never left my house . At that point I contacted SJ who sold me the boards to build a second DC3 but with the DC4 rectifier board , the transformer comes from Toroidy in Poland and the case is fortunately made in Italy . SJ was very collaborative and helpful in building my second lps giving a lot of hints .
Regarding the optical connection between TT2 and MScaler , as I said I never had the possibility to hear the benefits from a Wave Storm connection, so in some ways I will probably keep the doubt on which is the best solution. I can only say that it works a lot better than the cheap cables Chord provides .
Regarding the optical isolation on the network, I’m still using it but my friend Michele ( the previous owner of the DC3 and the MScaler) borrowed me his Etheregen and this little box opened my mind to a different way to implement the network connection to my streamer, a Chord 2GO/2YU which is also powered by its own self-made DC4 Lite lps. Unfortunately he wanted it back , but I think that it will be my future upgrade .
BTW, he uses it in combination with an expensive switch from Afterdark and thanks to this he removed the optical link on his network.
I think that together with its benefits, the MScaler brings a counterpart that is not easy to manage : it’s a noise generator that can easily be captured by the other devices and influence negatively their performance. For the moment the optical link is my way to go but I can’t exclude I will change it with something else in the future . I honestly don’t understand why Chord didn’t implement the optical link by default , but they might have their own good reasons as we don’t have all the details.
Mar 24, 2024 at 6:35 AM Post #159 of 170
This might interest you guys...
Mar 24, 2024 at 9:32 AM Post #160 of 170
He says exactly what i hear with my link.. Optical is the reference input.
With toslink from Mscaler to DAC you get an idea.. but full Mtaps with dual fiber is unbeatable.
Mar 24, 2024 at 3:22 PM Post #161 of 170
And also that a battery Dave is a good idea as well. :slight_smile:
Mar 24, 2024 at 3:59 PM Post #162 of 170
It was my idea to feed Dave with 140v pure DC. And i helped @stemiki to create the one that Rob talked about.
I wished i could hear his one.. combined with my dual optics then also 😁
Mar 29, 2024 at 3:02 PM Post #164 of 170
Would be nice to get in touch with @Reactcore and @stemiki to have more details on battery supply 😁
I leave the juicy details to Stemki.. as he went forward to create one.
Myself i hesitate to make one since my filter and mods sound soo good already.. but perhaps one day if i have spare time
Mar 31, 2024 at 2:04 PM Post #165 of 170
I tried what suggested by Rob Watts, I have to admit he is perfectly right . The key point is isolation from RF noise and opening ground loops. Even the use of a good Tos Link fiber between my 2GO/2YU streamer and Mscaler surprised me, it can go up to DSD64 with more details and natural sound than my expensive USB cable.
But I still keep the SJ linear psu for the streamer, may be because the original smps is like a phone charger (it's originally used only to charge the 2GO battery, but it must be kept connected to run the 2YU), probably a good smps like Ifi iPower X or Elite could surprise.
