Need help finding a Amp Switcher for 4x Amp & DAC's combo's & 2x Sources
Apr 19, 2024 at 11:14 PM Thread Starter Post #1 of 4
chrisyak
L.A.
I own 4 headphone amps with 4 DACs and would like to easily switch between them without constantly moving cables. My goal is to compare Amps/DACs, headphones, and switch amps for regular listening.
Ideally, I'd connect the switcher to one or two sources ( PC & Smartphone).
I googled very hard but to be honest I am unsure of a device that does this. So I did not have the most educated experience on what to search for which led me to a few products which may totally be wrong. I seen speaker switchers which I do not believe would work. I seen some lin switchers that look like their controlled by RCA. I also seen some switchers that use XLR.
I assume that there's probably a few factors into using an amp switcher that I potentially left out. So I thought I would come to the experts. Google is not an expert in audio equipment.
Here are a few devices I've found that might work but some of them don't seem to have enough connection s except for the Luxman.
Luxman AS-44: High-quality selector
LinkBone8×8 Matrix XLR switch
Kramer VS-4X: Pro-grade XLR switcher
Douk Audio 1(5)-in-5(1)-Out XLR Selector Box Audio Switcher 5-Way Splitter for Amplifier (1-IN-5-OUT)
Manley SKIPJACK = Too Expensive.
Thanks in advance for your help!
Apr 20, 2024 at 3:23 AM Post #2 of 4
You gotta make up your mind instead of having it all through one box.
If you want cheap: https://www.amazon.com/dp/B07R1XCNHG?ref=ppx_yo2ov_dt_b_product_details&th=1
1. They have 1 DAC to 3 Amp XLR.
2. They also have 3 DAC to 1 amp XLR.
3. If you want rca then search for it separately.
Basically you want something that doesn’t introduce extra electricity to the mix.
Apr 20, 2024 at 5:08 AM Post #3 of 4
So here is what I need to connect:
4x Amps or 5 Amps Max
4x Dacs or 5 Dacs Max
2x Sources or 3 Sources ( PC, Smartphone)
Don't want electrical interference.
I don't want to cheap out but don't want to pay a arm and leg. However, it has over 10K of equipment connected and does not include the headphones.
Maybe should buy a power cable and or line conditor and plug into surge protector.
Apr 20, 2024 at 10:48 AM Post #4 of 4
You should. The sound is better with power conditioner supposedly.
Your setup is rather convoluted. You need to just hire someone to build a DIY switch box.
