New FiiO M11S Player with dual ES9038Q2M DACs, 670mW output power and 14 hours of battery life
Apr 23, 2024 at 8:51 AM Post #631 of 641
That's not the point. I don't care about the resolution itself. I just want them to deliver what was promised... Don't confuse things.
I think it's YOU that's confusing things..
If it's labeled as Lossless, you already get the maximum quality that you could wish for. Adding a "hi-res" sticker to a lossless signal does NOT change the signal or the file, or the quality at all.
Apr 23, 2024 at 8:54 AM Post #632 of 641
I'm not confusing anything. It is only a charge in relation to the development of the streaming app and DAP FiiO software. Just it. The discussion is not about the Hi-Res sticker, marketing or resolution, but rather about what was promised by the companies responsible. It is up to the consumer to charge what was proposed.
Apr 23, 2024 at 11:10 AM Post #633 of 641
then you should contact Apple, since it's apparent that their app is not delivering the Hi-Res sticker to you..
How did Head-Fi become such a cesspool for weirdos?! :scream_cat:
Apr 23, 2024 at 1:32 PM Post #634 of 641
If I don't have different devices with different operating systems to correctly identify the source of the problem, there is no way to infer that the behavior is coming from Apple Music or the FiiO software. Note, I don't work as an Apple Music developer, much less as a FiiO developer.
Apr 23, 2024 at 3:14 PM Post #635 of 641
As defined by Apple -
Apple Lossless is CD quality: 16 bit at 44.1 kHz (kilohertz), and goes up to 24 bit at 48 kHz
Apple Hi-Res Lossless: 24 bit at 192 kHz
Apple Lossless vs. Hi-Res Lossless
I have seen the quality of the bit-rate on songs change between the 2 - sometimes it has to do with licensing, other times it could be data transmission, region, etc.
I did not see anywhere that Apple guarantees Hi-res Lossless vs. Lossless in their delivery (in fact they state that support can vary by all of these factors) AND you might want to check the settings on the app itself as you can specify different bit-rate based on streaming vs. download - I have seen the quality settings change when the app is updated to lower bit rates simply as it reverts to the default settings, so you might check there as well...
Apr 23, 2024 at 3:49 PM Post #636 of 641
I have already accessed the app's audio quality settings and selected the maximum (Hi-Res Lossless) on both Wi-Fi and mobile data. Additionally, I left the cache limit at maximum (5GB). Even using the FiiO M11S connected to my home's Wi-Fi, Apple Music reduces the resolution to "Lossless" every time. This is only resolved when I download the tracks. An iPhone user told me that the same thing happens to him, leading me to think that it is a problem with the Apple Music app itself.
Apr 24, 2024 at 3:09 AM Post #637 of 641
Dear friend,
We tested in Apple music but did not reproduce the issue. As for the classical version, we could not locate the reason for the problem currently. You could use the Apple msuic instead of the classical version for help? Are you using apple music app? Or the classical one?
Best regards
Apr 26, 2024 at 2:22 AM Post #638 of 641
The new firmware FW1.0.5 for M11S is now available!​
M11S firmware download link and update instruction: Click here
May 5, 2024 at 12:54 PM Post #639 of 641
Hi!
I want to know if anybody has the same issue. Everytime I go into Fiio Market, it keeps asking me to install Fiio Music, even if it's already done and has the latest version 3.2.1. Google Store also shows Fiio Music in the updates but can't upgrade it. Never had this issue before the last update. Thanks for your help!
May 5, 2024 at 2:14 PM Post #641 of 641
I've put my M11s up for sale on eBay in case anyone is looking for a terrific offer. (used for less than 5 hours in total, looks brand new, 1 year warranty left, sale in Europe only)
It's a great device, but I had to realise that I simply don't need it and it would just end up collecting dust here.
Already losing 300 bucks from what I've paid if only one person puts a bid on it. :scream_cat:
