wdahm519
- Aug 11, 2010
So I'm building a PIMETA v2. The parts are on their way right now and I'm getting ready to do the build. One of the last things I have to work out in my head is this:
1.) If I use both LED1 and LED2, will I still be able to do class A biasing?
EDIT: Found the answer myself:
"If you’re using LED2 for a panel-mounted power indicator and are also using the class A biasing feature, add the LED1 and RLED parts now. This is some combination of jumpers and diodes, depicted and described elsewhere. Regardless of how exactly you set this up, these parts need to go in now."
2.) What is the advantage of using both LED1 and LED2 together in class A biasing?
3.) Is it more advantageous to bypass LED2 and jumper it for class A biasing?
I feel like the explanation in Tangent's guide didn't quite answer this, at least for me.
Thanks,
Werner
Thanks,
Werner
