I am using it with AUKEY PA-D5 (rated max 63W although only 3A on 5V so theoretically 15W - but It didn't even get noticeably hot). So if your charger is not constant 65W and sth like usb plug charger you should be safe.Can you charge the mub1 with a 65w charger ? I know it will accept the charger and will only take what it needs , but will it blow up ?
qls mub 1
coldchillin81
what menu options are you referring to. I’ve looked for information on this but I’ve not found any.And the menu offers a lot of helpful options.
Any eq, crossfeed etc? Sound shaping options?
Stouthart
Of course not…no offense, but not functionality I would expect from such a device. I like my music bitperfect
coldchillin81
Thanks for the reply - what menu options are you referring to then?Of course not…no offense, but not functionality I would expect from such a device. I like my music bitperfect
I do expect that from these devices especially nowadays (gryphon, mojo 2, the FiiOs.. even the new cma18). I listen bit perfect sometimes when I’m driving Miss Daisy feeling civilized and sometimes I like to rev the engine and burn out when I’m feeling gone in 60 seconds
noplsestar
Hi there, I wrote a review of the wonderful MUB1, you can read it here:
https://www.head-fi.org/showcase/qls-hifi-mub1.26725/reviews
shimigg
- Mar 28, 2014
Where did you order the case from ?
Case arrived
I didn't find a case only order link
Mr.HiAudio
Member of the Trade: RIOBuds
I bought in an online store Ozon, in my case I bought a kit, but the seller forgot to put the case and sent it separately .Where did you order the case from ?
Unfortunately, this store is only for our country , sorry
Yes, I’ve used 65w chargers from Baseus and Anker and everything worked perfectly.Can you charge the mub1 with a 65w charger ? I know it will accept the charger and will only take what it needs , but will it blow up ?
If you use 65W charger from a reliable brand, certified QC, PD or any other certification, it should cause no problem to any device.
Anyone had a chance to compare MUB1 with the Qudelix T71 on planar headphones? The T71 claims 8Vrms and the best PEQ implementation, while also cheaper.
Mr.HiAudio
Good on Super gain and 80% of volume.
neobandog1
Mub1 vs qudelix T71 which have more fuller denser sound?
nihalsharma
The MUB1 stands out as an exceptional device, offering a comprehensive range of features within its compact form. It sounds amazing. It has a great battery life. It is powerful enough to fire up most of the iems and decent-sized cans. MUB1 effectively renders any potential use case for a dongle, especially the more expensive ones, obsolete. While its price may be higher compared to most dongles, its unparalleled performance justifies the investment. In my opinion, no other dongle can match the exceptional sound quality of the MUB1. It can also give a good fight to some more powerful dac/amps. I cannot really find anything that is missing with the MUB1. It gets a solid recommendation from me. A true 5/5 device.
Dropping some pics here.
SimpleAuricle
Can anyone comment on the playback controls such as pause/play/next, as well as the volume control? Does it work well when the device is connected via USB to your phone or computer? I’m really tempted to buy this
noplsestar
Everything works well. No flaws here!Can anyone comment on the playback controls such as pause/play/next, as well as the volume control? Does it work well when the device is connected via USB to your phone or computer? I’m really tempted to buy this
