Got some answers for you guys:
Inputs
DAC
Max Sample Rate/Bit-Depth
THD+N
SNR
— Questyle Team
@geoffalter11 At the moment, no, we are not planning on making a CMA Fifteen Master.Will there be a Fifteen Master?
@Audio Addict The CMA Twelve Master is very similar to the CMA Twelve (Standard), except with a ROGERS Ceramic PCB, which helps ensure the ultimate performance for sound quality by reducing resonance. I'll list below some of the bigger differences between the CMA Fifteen and the CMA Twelve Master for your reference:Any comparison to the Twelve Master, which I currently have?
Inputs
- The CMA Fifteen now comes with a USB-C port (keeping as well the CMA Twelve's USB-B port), which replaces the CMA Twelve's AES/EBU input.
- The CMA Fifteen now has analog inputs on the back. It's the first unit in the CMA series to have analog inputs.
- The CMA Fifteen now supports MQA (full/core decoder), whereas the CMA Twelve does not.
- The CMA Fifteen has a Bluetooth 5.0 input, which replaces the CMA Twelve's 5Ghz Wireless module (which allowed wireless streaming from a companion QP2R+Super Hub SHB2). This Bluetooth module supports LDAC, AAC, and SBC.
- The CMA Fifteen has an XMOS XU216 (16 core) USB decoder, whereas the CMA Twelve Master has an XMOS XU208 (8 core) USB decoder.
DAC
- The CMA Fifteen DAC chip is now the ESS ES9038Pro, while the CMA Twelve Master has the AKM AK4490EQ.
- PCM — CMA Fifteen supports up to 32-bit/768kHz | CMA Twelve supports up to 32-bit/384kHz
- DSD — CMA Fifteen supports up to DSD512 (native DSD) or DSD256 (DoP) | CMA Twelve supports up to DSD256 (native DSD) or DSD128 (DoP)
THD+N
- Headphone Amp — CMA Fifteen: <0.0003% @300Ω, <0.001% @32Ω | CMA Twelve Master: 0.00070% @300Ω, 0.00167% @32Ω
- Pre-Amp Output — CMA Fifteen: 0.0003% for XLR, 0.0004% for RCA | CMA Twelve Master: 0.00085% for XLR, 0.00115% for RCA
SNR
- Headphone Amp — CMA Fifteen: >117dB for 6.35mm, >120dB for 4.4mm balanced / XLR 4-PIN balanced | CMA Twelve Master: >112dB
- Pre-Amp Output — CMA Fifteen: >119dB for XLR, >116dB for RCA | CMA Twelve Master: >112dB for XLR, >109dB for RCA
@B Manoj Kumar We are still working to get the CMA Fifteen to India. At the moment, we are in talks with a couple distributors, and we hope to settle on a final distributor for India soon. Additionally, in the near future, the CMA Fifteen will be available from the Questyle official website, where we will be able to ship the item directly from our offices in China to any country.@Questyle - Would it be made available in India?
— Questyle Team
Thank you! We are certainly glad to be back and we are very proud of the 15! Hope you can get the chance to audition it soon.As a long-time Questyle fan and owner, I'd like to say welcome back to the West. If the 15 is as good or better than the 12, it will be a fabulous DAC/amp.
Stay updated on Questyle Audio Engineering at their sponsor profile on Head-Fi.
