jlbrach
- Jun 4, 2005
I agree the Tl-1b serves the purpose well
I'm pretty sure he is, and he has a point.Are you serious?
I’m likely an outlier but I wish they made the TI-1a still. Amp connector on the back works well with speaker taps.I agree the Tl-1b serves the purpose well
We have only the exact number of brick TI's to match the number of SR's currently in stock.Hi @Aleksandar R. , will there be an option to simply get the current drive interface in a small brick format? I don't love the aesthetics of the stand, and likely wouldn't use it even if I did. Apologies if this has been asked and answered elsewhere in the thread.
Stay updated on RAAL 1995 at their sponsor profile on Head-Fi.
Got it. So is the idea that future SR purchasers will get one of the new headphone stand interfaces that the Immanis and Magna use, or that you're going to discontinue the SR so there won't be any need for the interface bricks?We have only the exact number of brick TI's to match the number of SR's currently in stock.
I don't know when or if I'll make another batch of those.
Anyhow, the stem unscrews from the case, so this one also can be tucked next to the amp, but using less space.
Every solution has it's merits.Yeah, I love the brick form factor of the TI-1b, I'll be keeping that for my Magna/Immanis.
It's so solidly built, a flat rectangle fits better on a desk/shelf/entertainment stand, and it transports well, just throw it in a backpack.
No, the SR's are covered with the brick-TI. No need to buy the new stand with SR's.Got it. So is the idea that future SR purchasers will get one of the new headphone stand interfaces that the Immanis and Magna use, or that you're going to discontinue the SR so there won't be any need for the interface bricks?
The new one also has the amp input on the back, but using a lot less space. Unscrew the stand part and it's quite small and easier to place than TI-1a.I’m likely an outlier but I wish they made the TI-1a still. Amp connector on the back works well with speaker taps.
Yep, you're right about that.Hey Alex, I'm just wanting to echo what I've seen a few people on here say because I feel the same way. The cable for Immanis just doesn't seem to match it aesthetically. Is it possible to get it with a different sleeving? In my opinion a plain black sleeve would be fine or maybe something with gold/brown stitched in would complement the grill nicely.
Pretty much the kind that will be on the new cables!
The "Single metallic tracer" variants would be my favourite here.
I hadn’t thought about the ability to remove the stand. Certainly makes the new interface appealing.The new one also has the amp input on the back, but using a lot less space. Unscrew the stand part and it's quite small and easier to place than TI-1a.
Yes, there will be a nice screw down cap for the open hole where the stand used to be, so it will be very nice without the stand.I hadn’t thought about the ability to remove the stand. Certainly makes the new interface appealing.
