- Jan 29, 2010
Is that with the Hifiman adapter by any chance?The Raal CA-1A is also amazing off the Riviera AIC-10. I also use them off the speaker taps.
No I have a Danacable Nirvana speaker tap adapter that I use with my Susvara’s.Is that with the Hifiman adapter by any chance?
I'd recommend the TI-1b adapter box over the Jot R. The Jot R is a great amp, especially at its price point, but makes the SR1a sound a bit relentless and overly sharp and aggressive. It forces a lot of detail at you, and I found it fatiguing. On the other hand, it has strong bass, as far (i.e. deep) as the SR1a can do bass...The question is should I get an amp like Schiit Jotunheim R or TI-1b adaptor box to be used with WA33 amp.
WA33 works well with the TI-1A/B, on either load, they do sound different, and I can't remember which one I preferred, (I think 32 Ohms)You will need to find out the power output of the WA33 into various loads and then choose the transformer interface that matches the maximum output of the amp into that load, should you choose that route.
Danny or Aleksander should be able to answer your pinout question. Pine Tree Audio never asked that question so maybe I lucked out there.After @rlawry changed the "umbilical cable" between his headamp and the Ti-1b I am about to try the same thing. I wrote to Lavricables and they can reterminate a Grand headphone cable I already own to a 4pin male - 4pin male (1,5 meter - which makes it possible for me to sit 3 meters from my headamp).
I got the following question from Lavricables: Do you know the pinout for male xlr4 -> male xlr4 cable? Should it be one to one?
Do you have other comments about using a Grand cable as umbilical cable?
