utdeep
- Oct 15, 2001
INTRODUCTION:
All right! A lot of people are interested in the Plastics 1 mini to mini and the Ted's Earcandy mini to mini because they have nice L connectors. Both products can be purchased from Headroom's website, but you can get a better deal on the Earcandy at Todd's as of July 2004. Todd does not carry the Plastics cable.
After testing them out for a couple of hours, alternating between runs of the Gladiator soundtrack on Apple Lossless, using UE10's and an SR71 through a pocketdock on an iPod mini,I have a basic review.
AESTHETICS / DURABILITY / FUNCTIONALITY:
Plastic 1 Cable is small and thin. The connector is the same as the etymotics headphones and the ue's. Cord is extremely flexible and can bend to whatever you need it to be. It seems durable but in a minimalistic way, with a basic black plastic coating over what seem to be braided wires.
Ted's Earcandy cable has huge L-connectors which are extremely solid metal and the flexible portion doesn't begin till an inch after the connection. The wire is pretty thick and is brownish. One end of the cable is labeled "One Way" which is utterly stupid as the cable sound the same either way you plug it in so I can't see what the deal is. It definately has a more substancial feel than the Plastics 1 cable but is no where as flexible. A good analogy for this difference is twisting a water hose. The plastics one cable is like an empty hose - easy to twist and light; the earcandy would be a hose filled with water, with more heft to it and more struggle.
Functionality wise, the Plastics cable walks all over the Earcandy cable. The earcandy cable can only have the L connector facing up if you want access to the headphone jack of the SR-71, and is constricted by the volume knob on the other end. There is not enough space around the input hole to make the Earcandy connection less restricting. The plastics cable, due to it's small size does not cause a problem in any way. Considering that these cables are designed for small portable amps (as bigger amps generally use RCA to mini cables), this is a huge negative for the earcandy cable. I think it would be an issue when using it with the SR-71, Bithead, Airhead, Porta Corda etc. I worry if the earcandy cable could scratch the SR-71 or rip the pocket dock off my iPod if I give it a bad turn.
SOUND:
After two hours of listening, I have concluded that either the sound coming through both cables is identical or that I do not have the "golden" ears to recognize the difference. There were a few times where I noticed a subtle change in sound, but then I would go back to the other cable and realize that my mind had just not picked up on a subtle detail during my first listen. There were tiny tiny differences at times, but no matter how much I tried to, I could not derive any conclusions. Mind games?
CONCLUSION:
Considering the Plastics cable is only $20 while the Earcandy cable is $100, that they sound identical to me, and that the Plastics cable is more usable, I whole heartedly recommend it over the Earcandy cable. I purchased the earcandy to replace what I considered the cheapest link in my sound system, but it did not make the grade in my books.
I hope this helps someone.
SOUND:
CONCLUSION:
