Barone Birra
Maybe is Professional EQThe only thing that confuses me is the name. Why is it called PEQ if it's no parametric EQ?
Did I miss something?
Same issue I had with mine. Look on page one of this thread for a solution. I did the same thing - cut an adhesive label very thin and taped it on the center of each knob as a marker. It did the trick.I haven’t gone through all the posts here so if this has been addressed here before I apologize. The one thing I would change on my Loki Max is the knobs. Impossible to see the center mark from my listening position. I would like to change them out but I’m afraid I might damage it if I just pry them off. Has anyone done this? Also, what size is the knob shaft?
Well, I did that as well using decals but I ran into the problem of keeping it centered all the way down. Unlike many designs these don’t provide a way to tell where the center of the knob is.Same issue I had with mine. Look on page one of this thread for a solution. I did the same thing - cut an adhesive label very thin and taped it on the center of each knob as a marker. It did the trick.
Finally went and read the 'review'. Turns out it isn't a review but a recognition to a previous review (from June '23) which was very positive and guessing old new on this Loki thread.Absolute Sound Loki Max
Haven't read the review yet, but thought I'd share it while it's fresh. My initial thought having subscribed to Absolute Sound for years is 'they're reviewing Schiit? Don't they know Schiit doesn't make anything over $2K?' Second thought, maybe I should've read the review first as maybe AS is going to use this to dump on the whole affordable HiFi market.
You've heard from multiple people that have heard both components and listened to them for extended periods of time in their own system with music they are familiar with... or were these just conclusions / assumptions others came to "on the interwebs" (based on whatever reason)? The reason I ask is... it seems unlikely to be "common knowledge" that the Mac is better, or not... how many people have heard both? It would be interesting to test drive both, for sure.I have heard it is easily better than Loki Max. When the first chance comes along I’ll give it a listen.
I'm playing with an RME ADI-2 DAC FS... a very different piece than what is discussed here; however, "playing with some EQ" has been fun (and why I'm poking around the Loki Max). The RME has been interesting in some good (and bad) ways. I think I've come to the conclusion that I like it best WITH my Ayre KX-5 Twenty preamp, rather than using the RME direct (as a Preamp & DAC). Overall, it's been fun and I'll very likely keep it because it's just so flexible to use with different setups.Don’t know. Wanna hear it though. I will listen to any hardware balanced EQ I can get my hands on. Out of sheer curiosity. I know from personal experience that when you find a keeper in this department it ups your game (and your enjoyment) immensely. I am a huge proponent of studio grade high end balanced analog EQ. It’s the cats meow!
