tubey1
- Jun 26, 2011
Thanks for the encouragement. Here are some rather late responses.
@totalnoob43 I bought that one from Radio Shack.
@jgc731 There are two wires coming from the left speaker and two from the right that come over the headband. Both pairs have a ground wire (usually a bit larger and bare copper). They both go to the same terminal on the jack. Looking at my picture I think I have those two wires backwards. Do a Google search for "tip ring sleeve headphones". The tip is the left audio, the ring is the right audio, and the sleeve is the common ground.
@gyro55 I just use any old 5 minute epoxy.
Thanks for your posts. I'm about to try this mod.
On step 7, which wire is positive and which is negative? Is red positive?
