Shanling M6 Ultra - 4x AKM AK4493S DAC, Snapdragon 665, Android 10 DAP
Sep 15, 2023 at 4:34 AM Post #811 of 891
Is Roon Arc still not working on the latest release ? I can't even login ("Something went wrong" error). Roon Arc works fine on my phone, so looks like it's a problem with the M6 Ultra.
Seems like every new release breaks something, starting to question whether this was a good purchase...
Sep 17, 2023 at 10:14 PM Post #812 of 891
Still waiting for a fix for Roon Arc.
Sep 20, 2023 at 11:35 AM Post #813 of 891
Does somebody have somebody have the same discomfort as I have ?
The screen(or buttons ?) of M6U is too sensitive, when I put it into the pocket of jeans(shorts) then the player by itself is changing the track or it pause it, sometimes is very annoying.
I noticed the sometimes, I can change the track with different objects, not only with the finger.
In rest, the player have no issues(for me)
Sep 20, 2023 at 3:57 PM Post #814 of 891
Try using a passcode so the players stays locked without it. Worked for me.
Sep 20, 2023 at 9:19 PM Post #815 of 891
You can disable the buttons if you find them to be too sensitive. Available in system settings.
Sep 23, 2023 at 12:05 AM Post #816 of 891
how tight are your jeans? lol do you have double tap to unlock screen on? I turn it off when I'm going to be moving around with the player in my pocket.
Sep 24, 2023 at 9:54 PM Post #818 of 891
When the song has finished playing and the next song is about to be played The screen will turn on. Is there a way to stop the screen from turning on?
It shouldn't be doing this at all.
Please which firmware version are you running and what music app?
Sep 25, 2023 at 4:57 AM Post #820 of 891
FW: 1.28
Music App: UAPP
I don't have the M6 Ultra but suggest you try changing the notification options in android for UAPP. You could disable notifications altogether but that would remove the controls in the notification area too. Or leave it enabled and disable everything under it.
Oct 17, 2023 at 6:06 PM Post #822 of 891
Friends... just got my M6 Ultra... upgraded from M6 to have newer android version... (was very happy with M6 SQ and overall functions)..... this ultra sounds better and runs very well Apple Music.... but... but.... wifi is terrible, can not stream, just updated to 1.3 but same.... any ideas? Cheers !
Oct 17, 2023 at 6:09 PM Post #823 of 891
I have no issues with mine. Are you running 2.5g or 5g?
Oct 17, 2023 at 8:55 PM Post #824 of 891
Please what exact issue are you facing? Speed, distance, connection at all?
What modem are you using and what's its setting?
Oct 18, 2023 at 10:40 AM Post #825 of 891
There's a wifi bug that occurs with certain routers, which unfortunately has gone unfixed since the M6 Ultra was released. I've since switched to another DAP with the same Snapdragon 665 chip and no longer have this issue.
