doors97426
thank you for your answer but when using line out can you you use with the 4.4 is the amp not being used what does line out mode do is it the same using the usb-c or the 4.4
Line out is bypassing the amp stage of the M6. The DAC is converting to analogue and then handing off to your XD05 to amplify.thank you for your answer but when using line out can you you use with the 4.4 is the amp not being used what does line out mode do is it the same using the usb-c or the 4.4
